Introduction: Metal Puzzle Friendship Necklace
In this instructable I will show you how to make these really cute puzzle necklaces. I made the puzzle in a large variant for school a few years ago and now I wanted to do something a bit different with this puzzle. I'm not that good at soldering but I hope you like it!
Step 1: Materials
So what do you need?
- Wire ( I used two paperclips)
- Pliers
- Soldering iron
- Solder
- CD disc cleaning solution (something else would work as well but my dad had this)
- yarn
- Pliers
- Soldering iron
- Solder
- yarn
Step 2: The Heart
We're going to start with the heart. I didn't use precise measurements, the only important thing is that the middle of the heart is smaller than the loops of the straight and U-formed part. I reshaped it a little bit further in my process.
Step 3: Just a Straight Line
Take the same amount of wire you used for the heart and cut it in half. In this step we're just going to use one part of it. Make sure it is straight. Atr the beginning and at the end, bend loops. Twist them a bit so that they stand straight at the line. The size of the loops doesn't really matter, as long as the middle of the heart is smaller it is OK.
Step 4: U
Take the other half of your piece of wire. Again, bend te beginning and the end in a loop. Instead of leaving it straight, bend the middle into a U shape.
Open the loops for the U shape and add the straight line.
Now you can already start to puzzle. But, don't cheat, I'm watching you!
Step 5: Solder
There are a few points you will need to solder: The tip of the heart and the two loops of the straight line. Preheat the soldering iron. Hold it against the place you want to join. Then take you solder and put it on the heated join. Check your connections really good, it would be a pity if you lose one of the pieces because of a weak soldering spot.
Step 6: Clean It Up
The soldering joints probably look a bit filthy now. No worries, it can be cleaned. I used CD disc cleaning solution for this, but a lot of cleaning stuff will work. Just put a bit on a cotton swap and clean your soldering joints
Step 7: Yarning Time
If you like the pieces, it's time to turn them into pendants. Just take two pieces of yarn and add them to the pieces so you will get two necklaces.
Step 8: Done
Now you have your own unique metal puzzle friendship necklace! Look for someone to share it with :)
The solution? Really?????
Well, I could add another step but....
NO NO NO NO!!! This instructable does already contain a hint :)
