Introduction: Mini Half-Lap Rocket
There are a TON of things that people use every day made from flat materials… tables, cookie sheets, bookshelves, wooden Santa Clause puzzle kits, picture frames, and even this MDF rocket. Sure factories use automated power saws, die cutters, and tools that cost more than your house, but that’s only because those tools are required by manufacturers to keep their costs per item down. If you only have to make one of something, your technique doesn’t have to be so sophisticated. Even CNC machines and 3D printers can be overkill. The only tools you’ll need for some DIY projects are a sturdy work surface, a saw, and a drill.
Watch the YouTube video at It's Project Day!
Step 1: Draw Your Stencil
Draw the object you are going to cut out. Feel free to make anything you like. The guiding principle for the rockets was to make them symmetric with the half-laps made on the dividing line. If you want to use my design to make a rocket ship, print this PDF.
Step 2: Cut Out Stencil
Cut out the shapes. Make sure the cutouts are as clean as possible. They will become a stencil in the next step.
Step 3: Transfer the Stencil Image
Trace the stencils onto your material. Remember, the slots won’t work unless the material and the slots are both about 1/8in thick. If your material is a different size, adjust the slot width to match. Make sure to leave some room around the tracings so your cuts in the next steps won’t start right next to the finished cutout.
Step 4: Remove Bulk Material
Use a coping saw to cut between the two tracings and cut away most of the excess material. The idea is not to start cutting on the lines of the tracings, but rather to leave room so your cuts aren’t starting right next to the cutout in the next steps.
Step 5: Drill Out Half-Lap
Using a drill, drill a 1/8″ hole at the end of each of the two slots, this will make it easier to finish them. If you don’t have a drill available, you can use a back and forth method to clear the material from the end of the slot in step 7.
Step 6: Make Detailed Cutouts
Make your detailed cuts by cutting lines from the edges of your material to the sharp inside corners. Remember, coping saws can cut contours just fine, but it won’t cut hard angles easily and could even break your blade. Make multiple cuts to take the excess material away in wedges or strips.
Step 7: Cut Out Half-Lap Joints
Now that the exterior of the tracing is gone, cut the grooves. If you have a piece of thick scrap with a straight edge, you can clamp it to your cutout with the edge right on the line of the groove so as you cut, it will make sure the blade doesn’t go too far astray if you lose your line.
Step 8: Sand, Glue, Enjoy!
With the two halves of the rockets done, you can sand the edges smooth, put them together with a little glue in between, and you’re done!
If you’d like to add some finishing touches, you can paint them with a crazy design or add some LEDs for a retro high-tech effect
