Introduction: Multi-axis Phone Stand
This is my prototype version of a multi-axis phone stand. I got this idea from watching a tv show where they used a gyroscope chair which NASA use to simulate an out of control space shuttle.
Step 1: What I Used
(Sorry not all items are in these pictures)
Materials:
•2 plastic pizza trays (I got these from fridge pizzas I had got, but you could use wood)
• mobile phone case which you aren't afraid to ruin!
•some metal rods (I actually used rods from a Meccano kit I had and I used a few other but and bobs from this set)
Tools:
•scissors (I actually use a Stanley knife because I broke my scissors)
•super glue (I had to use PVA because I ran out but it works just the same)
•low tack tape
•ruler
•drawing compass
•pencil
•Popsicle stick to spread the glue
Step 2: How to Do Make It
I glued the 2 pizza dishes together (I used the low tack tape to keel them aligned). I then found the centre using the technique above on another tray. Then draw on 3 rings using the compass but leave a small gap between them because they will have to move past each other!
NOTE: the smallest ring must have a diameter slightly larger than the length between diagonal corners on your phone case!
Step 3:
Insert rods through the rings as shown by red lines in the photo. If you have done it right it should work like the the photo that followed.
Step 4:
To attach my phone I made a small structure which I attached to the make of my phone case ten screwed the structure onto the inner most ring.
Step 5:
I strengthened the rings with some of the Meccano as my iPhone 4s isn't very light compared to other phones. I then made a temporary stand to hold the rings out of the remaining Meccano and attached them to yet another pizza tray. (But you could use wood)
Step 6: And There You Go
Just put your phone in the case and there you go! You know have a multi axis phone stand which you can have on any position you desire!!!!
This took me 2 days but i started late at night before bed then finished it by lunch the next day. So you could probably make this in one day
