Introduction: Old Amplifier Knobs
Hi,
This is my first intructables, so please forgive any mistake and hope you like it! (Love your web page!!!)
Few weekends ago I was trying to find on the net some knobs to put on a old JVC amplifier my and my girlfriend found on the street... God I love London...
The small ones (2.5cm) where reasonable cheap and easy to find but I couldn't find any of 5cm...
So at last I decided to do them myself.
So here it comes:
So here it comes:
Step 1: The Knobs
1st: I decided to use the wood i had in my shed witch was plywood (you can also use MDF, depending on the finish you want once you going to paint it). I used a set of drills as shown in the picture. Be careful if you not using the central drillbit, it stars to spin really badly sometimes. There is other fix drillers you can use if you have them.
2nd: When I had the knobs cut I filled the little holes with filler i did myself using some wood dust from my sander and wood glue. Mix half and half (a bit less of glue) and apply.
3rd: Make some holes in the middle, use a ruler to do this. Use a drill bit about 5mm
4rd: Once is dry (allow a day) sand it. Cut a hexagonal metric screw and itroduce it on the hole so you can use it with the driller as shown on picture 06. I stapled some sanding paper (120 to start) to a peace of wood and I put some clothes in between to not be so scuare.
5th: I sanded with 600 sanding paper by hand to finish it.
Step 2: Paint the Knobs
Paint the knobs:
I used pink watercolor so I could see the texture of the wood. And i painted them pink because is for my girlfriend, and everything is pink at her place.
If you use MDF you can use then any quality acrylic or eggshell. Don't forget to seal it before painting.
Step 3: Last Detail
To make a little mark on the knob I used a electronic solder. It looks better than the picture...
Step 4: Final Result
Well, here it is!
