Introduction: POCU-WEATHER
About: I am a student at my high school innovating new ideas and will be spreading throughout the world.
POCU-WEATHER is a pocket-sized weather station. Which is Iot based application and helps in open-source monitoring of weather anywhere from the world.
Step 1: Gathering the Things Required
The Things required are:-
  1. Nodemcu
  2. DHT11 sensor module
  3. Breadboard
  4. wires
  5. PCB (if required)
Software requirements
  1. Arduino IDE
  2. Thingspeak
Step 2: The Connection
Connection:-
1) Nodemcu > oled
3v >> VCC
GND >> GND
D1 >> SDA
D2 >> SCL
2) Nodemcu >> DHT11
3v >> VCC
D6 >> DATA
GND >> GND
Step 3: Thingspeak
create an account in thingspeak. and paste the api in the code.
Step 4: Code
Step 5: Test
Test it with the data from Google and just compare yours will be more accurate than google because the ground station is far away from you and displays only satellite results which monitors somewhere top in the atmosphere. Even you can access using thingspeak.
Step 6: Contribute
