Introduction: PU Wheel Friction Drive E-Bike
This is a friction drive system I designed that uses PU wheel electric skateboard hub motor. I'm using SONY VTC6 18650 6S2P batteries(22.2v 6000MAH), got a top speed of 15km/hr on flat ground. Plan on doing some more tests with higher voltage batteries.
STL files: https://www.thingiverse.com/thing:2556492
Step 1: Prepare Parts Needed for the Build
Parts
1pcs M8 x 60mm bolt
3pcs M4 x 25mm bolts
3pcs M4 x 35mm bolts
3pcs M4 nyloc nuts
  • Battery : SONY VTC6 18650 6S2P (22.2v 6000MAH)
Step 2: ​Use 3pcs M4 X 35mm Screw and Nyloc Nuts to Mount TOP.STL and BOTTOM.STL Onto Bike
Step 3: Assemble Motor Mount With 3pcs M4 X 25mm Screws
Step 4: Use a M8 X 60mm Bolt and Nut to Hold Everything Together
Step 5: Find a Place to Mount the VESC
