Introduction: PVC Dual Shot Air Gun
This PVC air gun can be made for around $20. It is simple to make and fun to use.
Step 1: Parts and Supplies
Parts and Supplies list:
(3) 1/2 inch PVC valves
(1) 1/2 inch PVC 90 degree elbow
(1) 1/2 inch PVC Tee
(5) 2 inch long 1/2 inch PVC
(1) 4 inch long 1/2 inch PVC
(1) 13 inch long 1/2 inch PVC
(2) 7 inch long 1 1/2 inch PVC
(2) 1 1/2 inch PVC caps
(2) 1 1/2 inch PVC couplings
(2) 1 1/2 to 1/2 inch PVC reducers
(1) 3/8 inch schrader valve
Teflon tape
PVC purple primer and cement
Step 2: Attaching Schrader Valve
Attaching Schrader valve
- Take one 1 1/2 cap and drill a 3/8 inch hole in the center.
- Wrap Teflon tape around the threads of the Schrader valve.
- Screw in Schrader valve into the hole in the 1 1/2 inch PVC end cap.
Step 3: Making the Air Tanks
The air tanks
The Purple primer and PVC cement can get messy. I suggest putting a piece of card board underneath for easy clean up.
- Coat the outside of the PVC lengths with purple primer.
- Coat the inside of the PVC piece with PVC cement.
- Hold pieces tight together for about 10 seconds.
(repeat steps for both tanks)
Step 4: Making Barrel and Trigger
- Take the last 1/2 inch valve using purple primer and PVC cement attach a 2 inch piece of PVC.
Using purple primer and PVC cement attach the 13 inch piece of PVC to the valve.
Step 5: Final Assembly
Assembly
- Take one tank and attach the 90 degree elbow using purple primer and PVC cement.
- The Tee can can be attached to the last tank using purple primer and PVC cement.
- Connect both tanks with the 4 inch PVC length using purple primer and PVC cement.
- Add the barrel and trigger using purple primer and PVC cement.
- Let dry for 24 hours.
Step 6: Firing and Ammunition
Firing this air gun
- Close trigger valve.
- Fill air gun with 30-40 psi using a bike pump or air compressor.
- Close one of the tank valves.
- Load selected ammo into the barrel.
- Mini Marshmallows
- Foam darts
- Gumballs
- Paint balls
- Aim in a safe direction and open the barrel valve quickly.
- Close barrel valve and the open tank valve.
- Open other tank valve.
- Mini Marshmallows
- Foam darts
- Gumballs
- Paint balls
Repeat for endless fun.
Any other ammunition that you may try please leave a comment so I can try it out for myself. Hope you enjoy this creation as much as I do. Thanks for looking!
