Introduction: PVC Crossbow
this is an easy project and for you who are not patient your lucky because this
project has no glue, it can be made with scraps.
Step 1: Metirils
2-2 foot 1'' PVC
1-3.5 feet 1/2'' PVC
black tape
4 foot long piece of string
3-1'' long screws
TOOLS
drill
hack saw
1/2'' drill bit [or just big enough to fit the screw head]
5 millimeter drill bit [just smaller then the end of the screw]
[note-you don't have to use exact measurements and you don't have to the gray pipe]
black tape
3-1'' long screws
TOOLS
drill
hack saw
Step 2: Making the Bow
First you need to saw an inch down the middle as seen in picture 8 Then tie a not at the end of the string like in picture 6
Then slip it into the cut at the top of the pipe. then line up your string with the pipe like in picture 3 tie a not in the string about 6'' from the end of the pipe. Bend the pipe so that you can fit the knot in if it looks like picture 2 your set but if it is straight tie the knot farther away.
lastly put black tape on the edge like in picture 7 and 10.
Step 3: Spliting the Pipe
Next take your 2 foot 1'' pipe and saw as straight as you can right down the middle when you get to the middle of the pipe stop.
Step 4:
First make sure the pipe without the cut is about an inch away from where the other starts like in picture1 find where about the cut gos to and go 4 inches away from the cut so your not drilling under the cut drill a hole [with the big drill bit] like in picture 3 in the pipe without a cut then find where the hole lines up with the another pipe and drill a hole with the small bit like in picture 14 then screw a screw though both pipes like in picture 4 d the same thing 6 inches away from the first one on the side without the cut
Step 5: Puting the Bow On
put the string inside the split pipe then put the bow in the space in the pipes and tape it all up!
Step 6: Arrows
All you have to do to make arrows is split skewers
Step 7: Shoot
put the split end on the string pull back and let go! thats it thanks!
