Introduction: Painting and Basing a Miniature
Today we're gonna be painting and then basing some miniatures from a tabletop game.
Items required for painting and basing miniatures:
- Miniatures
- Assorted paints
- Spray paint primer (black or white)
- Gloss enamel primer
- Set of hobby brushes
- Spruce Cutter
- Set of Needle Files
- Hobby Turf Grass
- Hobby rocks
- Paper Towels
- Small container to hold water
- modeling paste
- super glue
- Elmer's glue
- cardboard
Step 1: Removing Excess Metal
Using the Spruce Cutters remove any extra metal hanging off the miniature and if needed use the needle files to remove anything too small for the cutters
Step 2: Clean Miniatures
Give the miniatures a quick wash to remove any oils or dirt leftover from the manufacturing process
Step 3: Spray Miniatures With Primer
Give each miniature a coat of primer, if needed give it time to dry before flipping if there was an area that could not be reached the first time. This base layer will make it easier for future paint to stick. White Primer usually helps the paints give a more vibrant feel while a black primer a darker tone. Make sure to do this in a well ventilated area and to keep the spray can pointed away from your body.
Step 4: Decide on a Color Scheme
Now would be a great time to decide on the paint scheme you'll be going for. Usually you can find a guide in the reference book related to the miniatures for one or two ways to color, although there are times when it is encouraged that you come up with your own to better customize and make the experience personal.
Step 5: Paint Base Colors
Apply the base colors, that is usually one or two colors that make up the majority of the miniature. If necessary give time in-between each color to allow the last coat to dry
Step 6: Paint Finer Details
Paint any miscellaneous details such as weapons, skin, and any other objects. If any mistake is made you can easily paint back with the base color.
Step 7: Apply Glossy Enamel
Repeat step similar to spraying with base primer but this time with a glossy enamel. This gives a protective layer to keep painting from chipping from use.
Step 8: Glue Miniatures to Base
Using some super glue glue the miniatures to the base (usually supplied along with miniatures). Make sure to get sufficient time to stick. There are special sprays that help quicken the super glue solidifying process if problems are encountered.
Step 9: Spread Modeling Paste
Using some modeling paste apply a small layer and allow time to completely dry. Once dry paint it an appropriate color to what you are aiming for, brown for an earthy feel or tan for sand.
Step 10: Add Extra Items
If desired you can add some grass or rocks. Apply a thin layer of Elmer's glue and spread around base, put the turf grass around and after giving some time to stick shake off any excess.
