Introduction: Plantation Project
About: i am piyush vijayvargia who is b.tech holder . i am working for a project . i looking for a job also which is working for a project.
THIS PROJECT IS BASICALLY FOR WATERING THE PLANT WHEN YOU AND YOU NOT LEAVE THE HOME .SUPPLY THE WATER TO TANK USING MOBILE PHONE
Step 1: Project Overview
this is the main source of plantation there is two pin one is motor and one is for water solenoid valve.when you send the message with the help of bluetooth and gsm then it supply the water to tank and plant
Step 2:
Step 3: Water Pipes for Plants
in this show how to connect the pipes to plants .in the middle of every plant pipes has a hole .when we supply the water so that it supply the plant with the help of hole
Step 4: Connect to Solenoid
in this electric water solenoid valve connect to the pipes. solenoid valve connects to the system with the help of adapter.it connect to the water pipeline which is the outlet of water motor.
Step 5: Voltage Supply
in this adapter pin supply to the system. and another one it is connect to the relay of solenoid valve
Step 6: Activate the System
now finally on the supply two lights is glown.one is for gsm. and another one is bluetooth.
Step 7: Working Part 1
Step 8: Working Part 2
