Introduction: Raw Jackfruit Curry
About: I like to make things more simple with easily available resources. My favorite quote: A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a…
We like to devour the tasteful pulps from a fully ripe jackfruits and discard everything else. But do you know that most parts of a raw unripe jackfruit can be cooked as normal vegetable other than the thorny outer skin?
Here is a simple recipe to make tasty curry from raw unripe jackfruits.
Step 1: Harvest or Buy a Raw Jackfruit
If you have jackfruit tree in your backyard, you can harvest a baby jackfruit or buy one from the vegetable market. A beetle or some insect has damaged the stalk of one of our young baby jackfruit. So I harvested the same to make jackfruit curry.
Step 2: Cut and Remove Thorny Skin
  • Cut the baby jackfruit in half. The fruit contains a sticky sap. Apply oil on your hands and the knife before cutting
  • Using an oiled knife, trim away the thorny skin.
  • Cut the skinned fruit into further small pieces.
Step 3: Remove Center Stalk and Cut Into Cubes
  • The jackfruit contains a center stalk which is not edible.
  • Using the knife remove the center stalk from all the pieces
  • Cut the fruit into small pieces of 3/4 inches in size
  • Wash and clean the cut pieces and drain out the water
Step 4: Add Turmeric Powder and Salt
  • Transfer the cut pieces into cooking vessel
  • Add about two teaspoons of turmeric powder
  • Add salt a little more than required. Most of the salt will be drained out with the water used for boiling
  • Mix everything together
Step 5: Boil the Jackfruit Cubes
  • Add clean water to the vessel so that it submerges all pieces in the vessel
  • Boil the pieces over medium fire.
  • You can cover the vessel with a lid during boiling
  • Check to see if the pieces are completely cooked.
Step 6: Drain Out Water
  • Once the jackfruit pieces are completely cooked and soft to touch, remove from fire.
  • Drain out the excess water using a strainer.
  • Leave the pieces in the strainer for about 15 to 20 minutes so that all excess water drains down.
Step 7: Grated Coconut and Spices
In the meantime grate half a coconut using a coconut grater and keep aside.
Also keep the following spices ready in a small dish
  • Two teaspoons of red chili powder (Add as per your own taste)
  • one and half teaspoons of Cumin seed powder
  • One teaspoon of Fennel seed powder
  • A pinch of Asafoetida powder
Step 8: Tempering
  • Heat a tablespoon of any cooking oil in a frying pan
  • When a oil is hot add a teaspoon of mustard seeds mixed with split black gram lentils
  • When the mustard seeds start cracking, add a bunch of curry leaves
Step 9: Add Spices
  • Now you can add the spices to the hot oil in the pan
  • Mix them well using a ladle till the spices are blended with the oil in the pan.
  • Add the boiled jackfruit pieces to the pan and mix well
    Step 10: Add the Grated Coconut
    • Add the grated coconut to the pan and mix with the jackfruit pieces.
    • Check for salt as some of the salt might have been drained out with water. Add if required
    • Remove from heat and transfer to a serving dish.
    The baby jackfruit curry has an excellent taste. You can eat it with rice, chapaties or bread
