Introduction: Rock Climbing Equipment Rack
Do you need a place to keep your carabiners, rope, chalk bag, and fancy climbing shoes? This climbing equipment rack will hold gear for two, and it features an adorable T-Rex making his way up a wall. (Silly T-Rex, if you’d developed that skill just a teensy bit earlier, you might have survived long enough to enjoy a mammalian buffet within an itty-bitty arm’s length.)
To make one:
To make one:
- Print out the .esp file provided in this instructable 3 times on 1/4" plywood. Only one of the prints needs to have the dinosaur graphic (the front print)
- Glue and clamp the three boards together using wood glue. Let it dry overnight. Be thorough with clamping all sides. Make sure there is contact at every point.
- Once glue is dry, screw pilot holes for gear hooks. Use pliers to twist screws in.
- Mount on wall with proper anchoring system. You can buy these at the hardware store and they come with directions.
- Climb on!
