Introduction: Scanner Rgb Led Lamp Pwm Controlled by Arduino Nano
About: Interested in everything that has to do with technology or science, but especially electronics and robots. Visit my site: http://bgprojectz.weebly.com/ or youtube: https://www.youtube.com/channel/UCPxUQL1lBaH…
Recycled scanner rgb led lamp pwm controlled by Arduino Nano
Step 1: Final Result
This is what you get if you follow this instructable.
Step 2: Find a Printer
Look for a broken hp all in one printer. (Other brands can also have the parts, but I used hp)
Try to find a relatively new model. The older ones sometimes have a CCFL lamp instead of LED lamp.
Step 3: Obtain the Rgb Led Lamp (1)
Look for this part in the scan unit of the printer.
Step 4: Obtain the Rgb Led Lamp (1)
Remove the motor part
Step 5: Obtain the Rgb Led Lamp (2)
Remove the solder from the 4 pins.
Be sure all the pins are completely detached from the pcb.
Step 6: Obtain the Rgb Led Lamp (3)
Put a screwdriver under the pcb (start at the opposite side of the desoldered pins) and pull the two pieces gently apart.
Step 7: Obtain the Rgb Led Lamp (4)
The pcb is now removed.
Turn the black plastic part upside down, and now you can remove the led lamp.
A screwdriver can be a useful.
Step 8: The Rgb Led Lamp
The actual led lamp is the small part with the 4 legs. The long white extension is a kind of prism light diffuser.
It's a common anode led (shared positive pin)
Pinout from top to bottom (if you hold the led as in my picture):
Green, Red, Blue, common anode
Step 9: Connect the Led With Arduino Nano
Connect the led as in the picture.
I don't know the exact specifications of this led, so I used resistor values slightly higher than probably necessary.
Resistors:
red: 200 Ohm
Green and blue: 150 Ohm
Step 10: Arduino Code
Upload the code to get the same effect as in my video
Or customize it to your liking.
