Introduction: Secret Door Card
Instruments :-
1) Scissors :- http://amzn.to/2q6RbZL
2) Craft Cutter :- http://amzn.to/2qvwIyT
3) Glue :- http://amzn.to/2qvwIyT
4) 30cm Ruler :- http://amzn.to/2qvwIyT
5) Paper Scoring Tools :- http://amzn.to/2qvwIyT
Materials :-
1) Designer Paper :- http://amzn.to/2pnQjRI
2) Thick Color Paper Sheet :- http://amzn.to/2pnQjRI
3) Ribbon :- http://amzn.to/2pnQjRI
4) Decorating Stuff
The card has secret compartment where you can hide your secret feelings, emotions and naughtiness......Follow the step thoroughly and have fun in life.
Step 1: Preparing the Base.
- Cut the Paper piece of size(12cm x 20cm)(H x L).
- Dive the piece into 4 equal part. Each part measures 5cm.
- Fold the card into half.
- Now on the other half section of the card , divide the on half section into 4 equal parts which measures 3cm each.
- Cut all the 3cm section.
- This will create 6 cm cut when the card is opened.
(Note:- If you unable to make the card by the steps listed above please refer all the images and the video at the last step to be confident.)
Step 2: Inserting the Secret Compartment.
- Take two strips of thick paper measuring (20cm x 5cm)(H x L).
- should be identical in color and size.
- Now take the first piece and sewing the first strip into the cut as shown in figure above.
- take the second strip and sew the strip alternating the first strip..
- you will get a checkered pattern at the end of the above step. Refer the images
- Close the adjacent flaps and you will have the card.
- Take a piece of paper measuring 8cm x 8cm.
- Apply a designer paper of you own desiring on it.
- Apply glue on the paper (Only on the half surface).
- Place it on the card as it forms a diamond shape.(Refer Images and Video in Step-3).
- Apply some decorative stuff to you card as you like and you secret door card is ready to perform it's task.
