Introduction: Setting Up and Configuring OpenHAB. Part 6 : IoT, Home Automation
Foreword
So, if you have followed the earlier parts (IoT - 'Intranet' of Things : Home Automation. Part 1 : IoT, Introduction onwards) you will have yourself an IoT network similar to that shown above (pic 2 and 3). In this part we will add the final touch. The user friendly front end which will allow you to view status, effect control, and visualise trending data all of which coming straight from your home environment via your IoT devices. This front end will be provided by OpenHAB (pic 4).
Introduction
This Instructable will detail how to do the following;
  1. Install OpenHAB and configure it to start up during the boot sequence of the Raspberry Pi
  2. Install Samba to allow for easier OpenHAB home site development, including adding new Icons
  3. Install OpenHAB Designer and show how to debug your code.
  4. Provision an example home site based on the earlier parts in this series, allowing the system full access to the exposed functionality in each IoT device.
What parts do I need?
  1. A home network
  2. Router with DCHP server
  3. One Raspberry Pi B+ or better
  4. One USB Hub, Keyboard, Mouse and LCD monitor to set up the Pi
  5. One Win 7 PC
  6. If you have followed all the preceding parts you can use the 3 off IoT devices to live test your OpenHAB server. Failing that you can use MQTTSpy (I have outlined how to carry out live and simulated testing below)
What skills do I need?
Realistically you will need the following;
  1. A truck load of patience.
  2. A better than average knowledge of Linux. If you have been following all the examples in this series, you will have more than adequate ability in this area.
  3. Some knowledge of Java or Eclipse Xtend (if you are looking to do more than just the simple examples you typically find on the internet)
Series Links
To Part 5 : Creating Your First IoT Ethernet Device. Part 5 : IoT, Home Automation
To Part 7 : Study Lights Controller (reworked). Part 7 : IoT, Home Automation
Step 1: Installing OpenHAB on Your Raspberry Pi
As mentioned above we will be using the OpenHAB server software for our user friendly front end, since like the Mosquitto MQTT Broker, its free and runs under Linux so it will work with the Raspberry Pi.
Preamble
As before I am assuming you have followed the steps in my earlier Instructable named 'IoT - Intranet of Things : Home Automation. Part 1 : IoT, Introduction' and have a Raspberry Pi already set up, connected to your network and ready to go.
All you need to do is make the following minor changes. Using PuTTY to connect to the Pi (MYHOSTNAME.local) and from the command line enter;
  • sudo raspi-config
Select option (8) Overclock and choose -> High 950MHz ARM, 250MHz Core, 450MHz SDRAM, 6 overvolt
Select option (9) Advanced Options then (A2) Hostname.
Enter 'OPENHAB' and save the changes.
Exit then choose to reboot the Pi
You can now re-connect PuTTY to this Pi by using the new hostname 'OPENHAB.local'.
Create a PuTTY saved session named 'OpenHAB', it will come in handy later.
Installation
The installation process is as follows;
Connect to your new OpenHAB server via PuTTY and remembering to copy Linux commands from this Instructable and paste them directly into PuTTY to avoid having to type any commands by hand. Answer Yes (y) to any questions.
Ensure you are in the home directory. If you are you will see the following prompt
pi@OPENHAB:~ $
If you don't see this enter
  • cd ~
Now complete the following commands;
  • sudo apt-get update
  • sudo apt-get upgrade
  • wget -qO - 'https://bintray.com/user/downloadSubjectPublicKey?username=openhab' | sudo apt-key add -
  • echo "deb http://dl.bintray.com/openhab/apt-repo stable main" | sudo tee /etc/apt/sources.list.d/openhab.list
  • sudo apt-get install openhab-runtime
now (required for sound playing later), edit the openhab file in defaults;
  • sudo nano /etc/default/openhab
change USER_AND_GROUP to root. ie.;
USER_AND_GROUP=root:root
and edit openhab.service under systemd;
  • sudo nano /usr/lib/systemd/system/openhab.service
also changing user and group to root ie.;
User=root
Group=root
then, finally;
  • sudo update-rc.d openhab defaults
  • sudo systemctl enable openhab
  • sudo chown -vhR pi:pi /etc/openhab
  • sudo chown -vhR pi:pi /usr/share/openhab
That's it you're done. OpenHAB has now been installed as a service and will automatically start when you boot your Raspberry Pi.
Now we need to configure it and test it works. However, first we will make our life a little easier by mapping some drives.
Note : OpenHAB requires Java version 1.7 or greater. Enter java -version at a PuTTY terminal window to find out what version your Raspberry Pi has installed. However, if you use the 'Rasbian Jessie' I used 2016-03-18-rasbian-jessie.img it is version 1.8, as below;
  • pi@OPENHAB:~ $ java -version
  • java version "1.8.0_65"
  • Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
  • Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
Step 2: Mapping Drives With Samba
In step 8 of the first Instructable of this series on home automation (IoT - 'Intranet' of Things : Home Automation. Part 1 : IoT, Introduction) I explained how to install Samba, the free, Linux drive mapping software. I'm going to recapitulate here and make some additions. These additions will make life a lot easier when it comes to configuration and editing your OpenHAB site with OpenHAB Designer.
Follow these steps with a PuTTY terminal window using OPENHAB.local as the Host Name (see pic 1 above), remember to use the copy and paste method so you don't need to type anything. Answer yes (y) to any prompts.
  • sudo apt-get install samba samba-common-bin
The next line invokes a command line editor named 'nano'
  • sudo nano /etc/samba/smb.conf
Once nano has opened the file smb.conf it will look like the picture above. Scroll up and down with the arrow keys until you reach the [global] section and find the line marked;
# wins support = no
and change it to yes and remove the '#'
wins support = yes
Now go to the [homes] section under Share Definitions and ensure;
read only = no
Next, go to the bottom of the file an add the following. Once again you can select all the text below, copy it and paste it into the PuTTY window by right clicking.
######## TEXT TO ADD : START #########
[pi]
comment= Home Directory
path=/home/pi
browseable=yes
writeable=yes
only guest=no
create mask=0777
directory mask=0777
public=no
force user=pi
force group=pi
[OpenHAB Home]
comment= OpenHAB Home
path=/usr/share/openhab
browseable=yes
writeable=yes
only guest=no
create mask=0777
directory mask=0777
public=no
force user=pi
force group=pi
[OpenHAB Config]
comment= OpenHAB Site Config
path=/etc/openhab
browseable=yes
writeable=yes
only guest=no
create mask=0777
directory mask=0777
public=no
force user=pi
force group=pi
######## TEXT TO ADD : END ##########
Now save and quit. Press ^X (the control, key and the 'x' key), then type 'y' followed by return. Thats it.
Finish off the setup with the following commands (this assumes you used the defaults u/n 'pi', p/w 'raspberry');
  • sudo smbpasswd -a pi
followed by password 'raspberry' twice
  • sudo update-rc.d smbd enable
  • sudo update-rc.d nmbd enable
  • sudo service smbd restart
We're done.
If you got it right you will be able to see your Raspberry Pi in windows explorer Network section named 'OPENHAB' as above (third pic). It will be showing three network connected folders; 'OpenHAB Config', 'OpenHAB Home' and 'pi'. We are going to 'map' two folders to help us use the OpenHAB Developer software; OpenHAB Config and Home. These will be mapped to Windows drive letters O:\ and P:\ respectively. Don't worry if you have something else mapped to these, just pick a different letter.
To Map 'OpenHAB Config';
  1. click on the 'OpenHAB config' share,
  2. right click select 'Map network drive...' from the drop down menu,
  3. Select Drive O:\,
  4. Folder should already be showing '\\OPENHAB\OpenHAB Config' or if it isn'tclick Browse and from dialogue box 'Browse For Folder' locate 'OpenHAB Config' under PC OPENHAB,
  5. Click OK,
  6. Ensure Reconnect at logon and Connect using different credentials are checked,
  7. Click Finish (see pic 4 above),
  8. Next 'Windows Security' dialogue box will appear, now select 'Use Another Account' and enter 'pi' for username and 'raspberry' for Password,
  9. Ensure 'Remember my credentials' is checked (see pic 5 above). You only have to do this once,
  10. Click ok.
Now repeat the process for 'OpenHAB Home' but this time name drive letter as P:\ to map to, and when the 'Map network drive' dialogue box appears don't check 'Connect using different credentials'. They will be remembered from the previous drive mapping for OpenHAB Config.
That's all you need to do, it will now look something like pic 6 above. You can now drag and drop any configuration files straight into the correct OpenHAB directories on the Raspberry Pi right from your windows PC. Each time you boot your windows pc and your OpenHAB server is running, windows will automatically reconnect the drive for you.
Hint : If at anytime you want to remove the drive mapping, just select the drive O:\ or P:\ from windows explorer, right click and choose 'Disconnect' from the drop down menu. Couldn't be any simpler.
Step 3: Configuring OpenHAB Server
General
Now we have installed OpenHAB and extended the Samba drive mappings we need to complete some customisation such that it runs correctly at each power up.
Customising is broken into two main constituent parts;
  1. Edits to OpenHAB configuration file 'openhab.cfg'
  2. Copy over of any addons
For the example home site I developed for this Instructable ('stevequinnhousehold') we will be using the following addon bindings and persistence;
  • MQTT Binding (for binding think of a way to connect to something. ie. the MQTT Broker, Mosquitto)
  • NTP Binding (this is to make up for the fact that the Pi doesn't have a real time clock to tell the time)
  • RRD4J Persistence (for persistence think values over time. ie. plotted points of temperature, humidity etc.)
Editing OpenHAB Configuration file
Make a copy of the configuration file in case you make any mistakes
  • sudo cp /etc/openhab/configurations/openhab_default.cfg /etc/openhab/configurations/openhab.cfg
Now edit this file and make the following changes. I am working on the assumption you are following this and the previous examples to the letter.
  • sudo nano /etc/openhab/configurations/openhab.cfg
Locate the Transport configurations section - 'MQTT Transport' and make the following changes;
#mqtt:{broker}.url=tcp://{host}:1883
mqtt:mosquitto.url=tcp://MQTTSVR.local:1883
then
#mqtt:{broker}.retain={retain}
mqtt:mosquitto.retain=true
Now locate the Binding configurations - 'NTP Binding' and make the following edits (Note: I picked the NTP server for the UK, if you are not in the UK you should check; http://support.ntp.org/bin/view/Servers/NTPPoolServers for your country's NTP server);
#ntp:refresh=
ntp:refresh=60000
then
#ntp:hostname=ptbtime1.ptb.de
ntp:hostname=0.uk.pool.ntp.org
Finally, under General configurations ensure persistence is set to the following;
persistence:default=rrd4j
Now save and quit nano. Press ^X (Ctrl-X) and y, then press return.
Copy over addons
Now we have completed our custom configuration it only remains to copy over the addons we will be using as part of the operation of the home site. To make your life easier in the future should you wish to extend the given example, we will get a copy of all the addons, but only 'install' the ones we need for now.
Enter the following commands to download and take a copy of all the bundled addons OpenHAB has to offer;
Note : There will be a lot of them to unzip so it may take a minute or so.
Now copy over those addons we will be using with the home site example.
  • sudo cp /usr/share/openhab/addons_repo/org.openhab.binding.mqtt-1.8.3.jar /usr/share/openhab/addons/org.openhab.binding.mqtt-1.8.3.jar
  • sudo cp /usr/share/openhab/addons_repo/org.openhab.binding.ntp-1.8.3.jar /usr/share/openhab/addons/org.openhab.binding.ntp-1.8.3.jar
  • sudo cp /usr/share/openhab/addons_repo/org.openhab.persistence.rrd4j-1.8.3.jar /usr/share/openhab/addons/org.openhab.persistence.rrd4j-1.8.3.jar
Now restart the openhab service and pick up your changes.
  • sudo service openhab restart
Ok, that's it, you're done.
Note : When you want to shut your Raspberry Pi down, enter
  • sudo shutdown now
When you restart your Raspberry Pi OpenHAB server, OpenHAB will automatically start using your custom configuration.
Hint : Useful Nano editing key combinations
  • ALT-M-A : Begin text selection
  • ALT-6 : Copy selected text
  • Ctrl-U : Paste text
  • Ctrl-K : Cut selected text
  • Ctrl-W : Find a text string
  • Ctrl-X : Quit and write changes (remember to choose 'y' to save your changes)
NOTE : for '{' read less than and for '}' read greater than. Unfortunately the Instructables editor strips these characters from your text.
Step 4: OpenHAB Designer
Introduction
As mentioned above, in order to create an OpenHAB home site all you need to do is edit some text files (.items, .sitemap as a minimum), to achieve this you can use a 'plain old' text editor like nano on the Raspberry Pi (or indeed use an editor on the PC, I prefer TextPad) and edit the files of interest, then save your changes and see it work via a browser refresh.
It is perfectly possible to work in this way and develop your OpenHAB site. The downside to this is you don't get any fancy 'bells and whistles' that an integrated development environment (IDE) would provide. Such as Microsoft's Visual Studio (TM) or Microchip's MPLABX (TM) offer.
To go some way to address this the OpenHAB team created OpenHAB Designer (OHD) whilst it is by no means as feature rich as the above IDEs it does give you some better feedback when writing your OpenHAB files. I give further details of this in the 'Debugging your rules' step.
Installation
Installation is relatively simple and requires the following three operations (for a Win 7 PC);
  1. Download and install the latest 32bit version of Java Runtime Environment (JRE),
  2. Download and unzip OpenHAB Designer
  3. Edit the file openHAB-Designer.ini file such that it points to the 32bit JRE.
Installation Steps;
  • Step 1 : Go here http://www.oracle.com/technetwork/java/javase/down... and download the 32bit JRE. See pic one. You are looking for 'jre-8u92-windows-i586.exe'. Once installed the software will reside here 'C:\Program Files (x86)\Java\jre1.8.0_92\bin'
  • Step 2 : Go here http://www.openhab.org/getting-started/downloads.h... and download openHAB Designer. See pic 2. Place the zip file 'distribution-1.8.3-designer-win.zip' anywhere and unzip it.
  • Step 3 : From your unzipped OHD directory locate the file named 'openHAB-Designer.ini' and add the following lines to the top of the file;
    • -vm
    • C:\Program Files (x86)\Java\jre1.8.0_92\bin\javaw.exe
I added a copy of the 'openHAB-Designer.ini' file I used below.
Editing your OpenHAB Home Site
To start OHD;
  1. Double click 'openHAB-Designer.exe'. You will be greeted by the screen in pic 3
  2. Click on the open file image as in pic 4
  3. Assuming you followed my advice regarding Samba, navigate to the configurations directory on your O:\ drive and click 'ok' (as in pic 5)
  4. You will then get the view in pic 6 detailing the important directories; Items, Persistence, Rules, Scripts, Sitemaps and Transform.
  5. You can now edit your existing files by double clicking on them in the top left hand pane (pic 7).
How do I create new files?
Assuming we want to create a new sitemap named 'sq.sitemap'
  1. Ensure OpenHAB Designer is closed
  2. From Windows explorer navigate to 'O:\configurations\sitemaps'
  3. Right click and select New -> Text Document
  4. Rename the text document sq.sitemap and click ok
  5. Click yes to the 'Rename' dialogue box which moans about a filename extension change making the file unusable
  6. Now start up OpenHAB Designer
  7. You will now see the new file under the Sitemaps folder.
Happy editing...
Gotchas
A. Use Google Chrome to view your OpenHAB Home Site from your PC. Internet Explorer hangs. Chrome is free and you can get it here; https://www.google.com/chrome/
B. One nagging issue I came across when using OpenHAB Designer was, if you restart the OpenHAB deamon via one of the following;
  1. Reboot your Raspberry Pi, sudo reboot now
  2. sudo service openhab restart
You will need to change the user:group on the OpenHAB files on the raspberry Pi from openhab:openhab to pi:pi or you will get a 'Save Problems' dialogue box as above (pic 8). You can do this by entering the following commands from a PuTTY terminal window.
It's a side effect (known issue) of installing OpenHAB Designer via apt-get install
C. Using OpenHAB Designer on the Raspberry Pi. In short you can't. Although the Pi is a Linux box OHD was built for x86 architectures. Straight from the horses mouth. Kai Kreuzer that is. See https://groups.google.com/forum/#!topic/openhab/-Ol42n-USn0
D. Don't use the OpenHAB Designer internal Browser, it's 'buggy'. Each time I used it, it just hung and I needed to use windows task manager to kill it off. Better to use Chrome as I mention. Also see https://github.com/openhab/openhab
Footnote
I didn't bother adding any reference to HABMin, since after having evaluating it I found it flaky and didn't integrate well into OpenHAB.
Step 5: OpenHAB Designer Significant Files
I have listed out above in the picture (pic 1) the files which are important to the successful use of OpenHAB and their respective locations.
If you wish to use the 'stevequinnhousehold' example all you need to do is unzip the contents of the zip file below and drop the files into the directories shown above.
If you have mapped your drives as I have this will only take minutes.
OpenHAB also has a demo home site you can experiment with. It can be downloaded from here http://www.openhab.org/getting-started/downloads.h... see pic 2 above.
The full details on the constituent parts of OpenHAB are described here;
Items : https://github.com/openhab/openhab/wiki/Explanatio...
Sitemaps : https://github.com/openhab/openhab/wiki/Explanatio...
Rules : https://github.com/openhab/openhab/wiki/Rules
Transform : https://github.com/openhab/openhab/wiki/Transforma...
Persistence : https://github.com/openhab/openhab/wiki/Persistenc...
Scripts : https://github.com/openhab/openhab/wiki/Scripts
Step 6: Steve Quinn Household - OpenHAB User Interface
The above pictures depict the home site I created for my series on home automation.
The main site is named 'stevequinnhousehold' with IoT devices placed in the Garage, Study and Guest Bedroom respectively. Picture one outlines the menu structure and the remaining pictures the contents of these pages.
I have added the ability to view or change all the exposed functionality present in each the IoT devices the earlier parts of this series detail how to create and have also added in 'persistence' such that dynamic graphs of barometric pressure, temperature, humidity and heat index are displayed.
Once the files which make up 'stevequinnhousehold' have been installed on your OpenHAB server, to view the home site you will need to enter the following in Google Chrome.
http://openhab.local:8080/openhab.app?sitemap=stevequinnhousehold
Hint : What do I mean by exposed functionality? Simply anything within the IoT device which can be read from or written to via MQTT. So for instance, the Garage IoT device has an LED and DHT22 sensor which means it has a local output (red LED) and some local input (temperature and humidity, Heat Index is calculated). The code in the IoT device allows a remote publisher to turn on and off the LED with '/WiFiDevice/Led2Command' topic publications and a remote subscriber to receive topic publications as the device will periodically publish its local Temperature, Humidity and Heat Index if they change via /WiFiDevice/Temp1Status, /WiFiDevice/Humd1Status and /WiFiDevice/HeatInd1Status. If you look at the OpenHAB web page for the Garage you will see all of these items represented by icons, values (Degrees C and percentage) and a switch.
Step 7: There Are IOS OpenHAB Clients
So are there any other ways you can view the OpenHAB home site?
Yes, OpenHAB offer applications for iOS and android.
Screen shots of the iPad iOS version are shown above
Step 8: And Not to Leave Out Android Users
And for Android users the App Store has the following OpenHAB App.
Step 9: Debugging Your Rules
There are typically a few options open to you when debugging OpenHAB (on the Raspberry Pi) with OpenHAB Designer (on the PC). These are Semantic and Functional debugging.
Semantic Debugging
If you do opt to use OpenHAB Designer, one of the benefits of the software is it will help you pickup any semantic errors by highlighting the line in error with a red 'x' (in pic 3 above), here the software has detected the random text error 'ThisIsABlatantMistake' and highlighted it.
The software will also help you complete your code by offering any potential alternatives (as in pic 2 above). To obtain this help whilst typing, simply press Ctrl-SPACE. A short while later a drop down menu will appear detailing the possible alternatives. Use the up/down arrow keys to make your selection and press enter to make your choice.
Functional Debugging
This area of debug is a little tricky. Once you have entered all your code for .sitemap, .rules, .persist, Transforms(MAPS, Java Scripts etc) and .items which is reasonably straight forward. You can point your Chrome browser to your home site (http://openhab.local:8080/openhab.app?sitemap=stevequinnhousehold), refresh it and see the fruit of your labour before your very eyes.
But what happens if you are working on a rule and you get no response or a response in Chome which makes no sense. If such a situation occurs then you can use logging to help you to debug. See https://github.com/openhab/wiki/Rules for further details (generalised process depicted in pic 1). However in short you can effectively carryout print statement debugging if you do the following (pics 4 and 5 above);
    Open PuTTY, connect to your OpenHAB Server and enter;
    • tail -f /var/log/openhab/openhab.log
    • To switch on logging within your rules, edit the logback.xml file;
      • sudo nano /etc/openhab/logback.xml
    • Locate the following line;
      • {logger name="org.openhab" level="INFO" /}
    • Enter this below it;
      • {logger name="org.openhab.model.script.stevequinnhousehold" level="DEBUG"/}
    • Save your changes and quit nano ^X, y, return
    • Add the following line to your rules file, in the rule of interest. ie the one you are debugging.
      • logDebug("stevequinnhousehold","Rule being debugged")
    • Save your changes to the .rule file in OpenHAB Designer.
    • A short time later the tailed log will show the changes being read by the OpenHAB server : 'Refreshing model 'stevequinnhousehold''
    • When your rule executes the code of interest the following will appear in the tailed log;
      • YYYY-MM-DD HH:MM:SS.S [DEBUG] [del.script.stevequinnhousehold] - Rule being debugged
    So by using this method you can print debug your software until you fix any issues. To help your understanding I left some debugging code in the stevequinnhousehold.rules file, 'Sync Controls' rule.
    Hint : Quitting a running command line program.
    There are some subtle differences when you exit a program on a Linux system using ^C (Ctrl-C) and ^Z (Ctrl-Z). Depending on how you use these commands you may get what think is strange behaviour.
    Ctrl-C : This command will exit and terminate a running program. You could use it to quit from the tailed log example above.
    Ctrl-Z : This command suspends a program and gives you back the command line. In effect your previously invoked program is still in memory but gets no processor time. To correctly terminate a program after using ^Z, you will need to re-activate the suspended program by entering fg then ^C. If you restart a program that was suspended with ^Z you may find odd behaviour given the program is effectively still loaded before trying to load over the top.
    Step 10: Making Your Own Icons
    Making your own icons for OpenHAB is reasonably simple. I used Microsoft Paint (TM) to create mine.
    All you need to do is to carryout the following steps;
    1. Run up paint,
    2. Select Properties (pic above),
    3. From Image Properties dialogue box, select, Units = Pixels,
    4. Enter Width and Height = 32,
    5. Click Ok,
    6. Zoom in on your image. It will be very small (pic above),
    7. Make your edits,
    8. Save as a .png file.
    Copy the .png file to your OpenHAB Rasperry Pi Server in the following directory;
    • /usr/share/openhab/webapps/images
    or if you have mapped the directories as I have you simply drag and drop them into (pic above);
    • O:\webapps\images
    Once you have done this you need to change the file attributes by entering the following from a PuTTY window;
    • cd /usr/share/openhab/webapps/images
    And that's it. Now you can reference your new icons in your .items file. So for humidity.png that would be {humidity}. You just miss off the .png.
    Alternatively you could plagiarise from a web site (I found these useful);
    Although I have included a copy of the icons I used in the OpenHAB Designer step I have also included a zipped copy below.
    One point to Note, if you use Paint. The image is not layered so it will always have a background colour. I chose white.
    Step 11: Testing Your OpenHAB Site
    There are essentially two ways you can test your hard work as depicted above.
    1. You can use live IoT device data
    2. You could use simulated MQTT traffic with MQTTSpy
    There are merits in using both, which is how I did my testing.
    Live data is great for real world testing, but is non-deterministic. In otherwords if you are trying to track down a bug that only occurs after a strange sequence of events. This is not the best method to use. you are better off deploying MQTTSpy.
    I have included video clips of both typical test scenarios above.
    For the simulated data testing I connected to the MQTT broker 'MQTTSVR' with MQTTSpy using the client-Id 'WIZNet5100-de:ed:ba:fe:fe:ee' such that it looked like the Ethernet Device I had connected earlier in the day.
    I then Simulated the following;
    • From MQTTSpy to OpenHAB : Remote Logfile Open/Close Button Push
    • From OpenHAB to MQTTSpy : Logging Period Update, Time and Date Set
    • From MQTTSpy to OpenHAB : Remote Button Pressed/Released
    • From MQTTSpy to OpenHAB : Barometric Pressure update
    For live data testing I picked out a few representative items to check. It was interesting to note that during testing I needed to refresh Chrome for it to pick up the Icon changes when setting the logging state. Also you will notice that the remote temperature is showing 'TR: 00.00' on the blue LCD display, this is because after resetting the Ethernet IoT device prior to shooting the video, the remote garage temperature sensor hadn't picked up any changes in ambient temperature, so there were no updates to the default initialised value of 00.00. However the temperature trend OpenHAB displayed showed a constant (persisted) 19.20 Deg C.
    Step 12: Conclusion
    So, if you have been following all the steps in this series, you will by now be adept in setting up, developing, debugging and extending your own intranet of things. Hopefully the main thread was relatively easy to follow and you feel confident about making your own IoT network.
    What would I have done differently?
    The naming convention of the MQTT topics I think was a little on the rushed side and really needs a lot of thought. I did find two useful sites where this topic was discussed to some extent. They are listed in the next step.
    Developing rules was a steep learning curve I think I would have done much better had I learned Java and Xtend before trying to tackle home site development. I needed to do a lot of reading round to 'get a grip' on this.
    Bones of contention
    I was unable to get the System Startup Rule working, no matter what I tried. I did a lot of 'googling' and did not I was not the only OpenHAB user to have experienced this.
    Graphs flickering. This is a known issue to overcome this I changed the layout of the home site 'pushing' the graphs down into sub-menus to prevent constant screen updates.
    Where next?
    I am in the process of developing some extra IoT devices for my network which I will getting round to publishing when the bits arrive from China;
    1. TV Simulator
    2. Mains switch
    3. Facial/Image recognition door lock (mainly for comedy value with OpenCV rather than actual deployment)
    Acknowledgements
    Thanks go to the following OpenHAB community members;
    'sihui' : https://community.openhab.org/users/sihui/activity and
    'watou' : https://community.openhab.org/users/watou/activity
    for their help in understanding OpenHAB Designer and Mapping of MQTT inputs respectively.
    Step 13: References Used
    I used the following references to put this instructable together;
    OpenHAB Site
    OpenHAB Community Site
    OpenHAB Detailed Guides
    OpenHAB installation guides
    OpenHAB Supported platforms/Raspberry Pi Acceleration Tips
    OpenHAB Designer
    Persistence and graphs
    OpenHAB trending flicker
    Configuring OpenHAB
    OpenHAB downloads site
    Debugging OpenHAB
    OpenHAB G+ Site
    NTP Server page
    Further reading on underlying OpenHAB coding language
    General Linux stuff
    Good overviews and projects pages
    Icons
