Introduction: Snickers Bites
These crunchy, peanut buttery, caramely, chocolaty bites are not only delicious, they are also super easy to make.
Step 1: The Ingredients
Ingredients
Sugar
  • 1 dl or
  • 90 grams or
  • 0.42 cups
Baking syrup
  • 2 dl or
  • 280 grams or
  • 0.85 cups
Peanut butter
  • 1 jar or
  • 340 grams or
  • 12 oz
Plain Cornflakes
  • 11 dl or
  • 220 grams or
  • 4.65 cups
Dark chocolate chips
  • 200 grams or
  • 7 oz
Vanilla
  • Powder: a tiny smidgen or
  • Extract: a dash
Step 2: The Crunchy
Add the corn flakes to a large bowl, and if you are using vanilla powder, sprinkle it over, and set aside.
Step 3: The Caramely and the Peanut Buttery
To a pan add the sugar and the syrup and on low/medium heat allow it to slowly come to a boil. Then, take it of the heat and stir in the peanut butter. If you are using vanilla extract, mix it in.
Step 4: The Assembly
Pour the peanut butter mixture over the corn flakes and thoroughly but gently mix everything together. Transfer into a large pan and flatten it out to a thickness of about 2 cm, slightly thinner than one inch. Melt the chocolate and coat the top of the slab. Before the chocolate has fully set, cut into bite sized pieces using a bench scraper.
Once everything is cool to the touch and the chocolate is set, transfer the bites into a container, separating the layers with parchment paper. Store the bites in the freezer. Serve the bites while still very cold, but not frozen enough to break any teeth.
Enjoy!
