Introduction: Sprouting Alfalfa Sprouts in a Mason Jar
About: Lifelong technology geek
Sprouting Alfalfa seeds is an inexpensive (and really easy) way to add some thing extra to any meal. To get the best salads, flavorings and some variety affordably, you have to have the freshest and cleanest ingredients. To have the freshest and cleanest, you should grow your own. Many spices and herbs can be grown indoors in a small greenhouse (you can see my TouchScreen GreenHouse instructable here), but you can also use a simple mason jar to sprout a variety of seeds in just a few days.
This instructable will walk you through growing Alfalfa sprouts in a mason jar in only a few days. It’s easy, it’s inexpensive, it’s good for you, and it even tastes good. So, let’s grow some sprouts.
Step 1: What You Need
Getting started is easy, All you need is:
  • A mason jar
  • A small screen top or some cheesecloth
  • Alfalfa seeds (you can also sprout chickpeas and many others)
  • Water
  • A Cool, dry spot out of the sun
Step 2: Getting Started
As a ‘general rule’ if the seeds come from a big brand sold as generic planting seeds in a package, they have likely been treated or modified and should be avoided. Try and get seeds from health food stores or gardening supply outlets that provide organic and untreated seeds.
First, pour some seeds into the mason jar. When just getting started, pour just enough to barely cover the base evenly at most. The seeds will expand and sprout quickly, so use just enough for what you will use - although they can be refrigerated for short periods. After a few harvests, you will have a good feel for how many you need and the jar will hold. If you really enjoy the sprouts, try and stagger several mason jars over different days.
With the seeds in place, cover the top with the screen or cheesecloth. If you use cheesecloth it can be secured with a rubber band. Fill the mason jar about half-full of water and set aside for 8-12 hours for a good soak.
After the initial soaking time, with the top in place, drain the water, refill the jar with water about half way again, rinse well and drain again. Place the mason jar in a spot out of direct sunlight slightly elevated with the “top side” lowest. This will allow the seeds to dry freely. Let them sit overnight.
Step 3: The Routine
Over the next few days the seeds will begin sprouting quickly, but will need to be continually rehydrated. Each day, rinse the seeds in their jar, making sure to get all of them moist, and then drain. Two times a day is a basic minimum, 4 or 5 times is ideal. After each draining, place the jar back in its leaning position out of sunlight.
Step 4: The Harvest!
After 3-5 days the sprouts should have grown about an inch or so long. When they are, they are ready to enjoy. Depending on personal taste, when the sprouts are ready, you have the option of placing the jar in the sunlight for a few hours and letting the sprouts green by producing some chlorophyl (remember 8th grade science!) or eating them as is. On the 3rd day, I let these sit for about 2 hours in the sun (the 2nd shot).
When you’re ready to use the sprouts, remove them from their jar, rinse really well (a few minutes or so) in a colander to remove the chaff and shells. Remove any sprouts that may not look “healthy” or unsprouted and add raw to salads or as a side. While many beans and sprouts can be cooked, Alfalfa will get soggy, but again, it’s a matter of personal taste. Try different ideas and beans, look for recipes on-line and be creative. Just knowing that you are growing your own healthy ingredients is enough to start making a difference, so get started - it really is fun and easy!
If you need to refrigerate the sprouts, wrap the sprouts in a dry paper towel, place in a sealed plastic baggy and refrigerate for up to a few days. I didn't include any shots of the salad, but they were delicious!
That was easy!
