Introduction: Studio Lamp
Clamp lights are a simple and inexpensive way to provide a lot of light when you need it. But sometimes there just isn't anything around to clamp onto! Studio lamp is a simple solution that allows you to position and adjust your clamp light exactly where you want it, quickly and easily.
Step 1: Materials
Here's what you'll need:
1 clamp light w/ cord
1 light bulb (60w)
1 camera tripod w/ pan & tilt
* Approx. 2 sq ft of floor space
With any luck, you'll have a few of these things already. If you're starting from scratch you will need about $30.
1 light bulb (60w)
Step 2: Clamp It
Work those forearms and clamp your light to the pan/tilt head of the tripod until you feel you've got a secure grip. (Once it's on tight you'll know it)
Step 3: Adjust
Setup your tripod to the desired height and adjust the fixed position of the light using the integrated ball joint. You did it! Now you can use the pan/tilt arm on the head of the tripod to easily adjust the direction of the light whenever you want. At about 2 lbs altogether, moving around is no problem either. Enjoy!
