The Suitcase Boombox is a vintage suitcase converted into a boombox, complete with two subwoofers and four tweeters. The whole system is powered by two lead acid batteries hooked up to a charge controller, so the boombox can be charged via an AC/DC power supply or even a solar panel. The mini amplifier delivers 25 watts of power per channel, giving the system a lot of volume, comparable to a car audio system. You could definitely take this out to the park and start your own mini dance party or use it to play loud music in your room. What I love most about this project is that no two suitcase boomboxes will ever look the same. Depending on the type of suitcase you use and the size and configuration of your speaker setup, there is plenty of room to apply your own personal style to the project and make something truly unique.
Parts List:
(1x) Vintage Suitcase (I found mine on Etsy) (2x) 12V/4Ah Sealed Lead Acid Battery Radioshack 55034004 (1x) Pioneer TS-D1720C 6.75" Component Speaker Package Radioshack 55032192 (1x) Pioneer TS-D1720C 5.25" Component Speaker Package Radioshack 55032190 (I ended up only using the tweeters from this package and saving the 5.25" speakers for another project. You can also replace this part with any other 4Ohm tweeter.) (1x) Sunforce 30-Amp Digital Charge Controller Radioshack 277-110 (1x) Topping TP20-MK2 MKII TA2020 Class T-AMP Digital Stereo Amplifier Amazon (1x) 3-Ft. 1/8" Stereo to Dual Phono (RCA) Plug Y-cable Radioshack 42-494 (1x) 1/8" Stereo In-Line Audio Jack Radioshack 274-274 (1x) 1/8" Stereo Panel-Mount Audio Jack Radioshack 274-249 (1x) 3-Ft. 1/8" Stereo Plug Cable Radioshack 42-223 (1x) 50-Ft. 16-Gauge Clear 2-Conductor Speaker Wire Radioshack 278-1267 (you will only need about 15ft) (1x) 22 Gauge stranded wire, multiple colors Radioshack 278-1224 (1x) black electrical tape Radioshack 64-2373 (1x) Size M Panel-mount Coaxial DC Power Jack Radioshack 274-1563 (1x) AC-DC 12V 1.5A Power Supply Radioshack 273-316 (1x) M type plug Radioshack 273-344 (1x) 3/16" battery terminal connectors Radioshack 64-3132
Additional Materials/Tools:
Wire Cutters/Strippers Radioshack 64-224 Rosin Core Solder Radioshack 64-009 Soldering Iron Radioshack 55027897 Razor Blade Cutting Tool (for cutting leather suitcase) Power Drill Dremel Screws (be sure to get some that match the hardware on your suitcase) Locknuts/nylon nuts (for areas of high vibration) and regular nuts Small L-Brackets Screwdriver 1/4" plywood - I needed this to add some structural support to my suitcase, if you use a hard clamshell case, you may not require any additional support. scrap wood (for mounting charge controller) marking pen metal file wire crimper Radioshack 64-225
Step 1: Layout Speakers
This step will vary from suitcase to suitcase. My suitcase was 20" wide and 11" tall, this was enough space to mount two 6.75" subwoofers and four 1.75" tweeters. I cut out paper to help visualize the layout of the speakers on the side of the case. Eventually I settled on a symmetric layout, with the two subs in the bottom center, and the tweeters along the upper corners.
Step 2: Clean Out Suitcase
You'll want to clear out a lot of room to mount all your components to the inside of the suitcase. Use a razor blade to cut out any excess material (cushions, fabric dividers) and remove any extraneous hardware (clips, brackets) with a screwdriver.
Save these scraps, you might use them later in the project (I used them to make a pocket for holding my iPod).
Step 3: Cut Out Suitcase Lining
I used a blade again to cut out the lining of the suitcase, on the side where I planned on mounting my speakers. I also cut out some warped, plastic corner pieces that were sticking up.
The walls of my suitcase are made of leather with a fabric lining, on their own they will not be able to support the weight of 2 subs and 4 tweeters. I cut out a piece of 1/4" plywood so that it could fit snugly against the wall of my suitcase and provide extra support. I used a laser cutter to cut out the speaker mounting holes (pdf of cutlines attached below), these cuts could also be cut with a jigsaw or Coping saw. I kept the tolerance of my support structure tight, so it essentially press fit up against the suitcase wall.
I used my structural support as a guide to trace cutlines onto the inside surface of the suitcase with a pen.
Step 6: Cut Holes in Suitcase Wall
Carefully cut along the traces and create holes for mounting your speakers. I was able to get away with using a razor blade cutter to get through the leather sides of my case. If a razor blade cutter is not enough to get through your suitcase, a jigsaw or Coping saw will probably do the trick.
Again, save these leather scraps, you might use them later in the project.
Step 7: Remove Front Panel From Subwoofers
Press the tabs around the inside edge of each of the subwoofer covers to remove the mesh front panel from the edge guard.
Step 8: Mount Subwoofers
The Pioneer kit comes with hardware for mounting the speaker components. Use the eight longest screws in the kit to mount the two subs to the front of the suitcase. Use a nylon nut to secure to back end of the screws and prevent vibrational loosening. You might also considering finding a screw with a matching locknut. File down the pointy edge of the screw so you don't accidentally scratch yourself.
Step 9: Mount Tweeters
I cut my backing wood panel with such a tight tolerance that the tweeters press fit into the side of the suitcase enclosure. For added stability, I used the metal inserts and screws from the pioneer kit to hold the tweeters in place from the inside of the suitcase (though this is not their intended purpose, it worked really nicely for me). Depending on your setup, you might also consider using some of the kit's other mounting options.
Step 10: Remove Lining of Back Panel and Reinforce With Wood
As with the front panel, use a blade to clear out any loose material attached to the back panel.
Step 11: Layout Remaining Components
Organize the remaining components around the back panel and mark drill holes. I used two pieces of 2' wood scrap to prop up my charge controller above the surface of the plywood support. Make sure the case will close before you finalize your layout!
Step 12: Passive Crossovers
The Pioneer kit comes with passive crossovers to split up each channel of audio from the amplifier into a signal for the sub and a signal for the tweeters. Use screws to mount both crossovers onto the side of the suitcase, opposite from the speakers. Note - nearly all of my screws were screwed through the 1/4 plywood backer, but not through the suitcase enclose.
Step 13: Wire Crossovers to Amplifier
Cut and strip a 2-3' piece of speaker wire (long enough so you can easily open the suitcase without putting tension on the wire) and use it to connect one crossover to the amp's left output and other to the right output. Be sure to connect the + crossover input to the + amplifier output.
Step 14: Wire Woofers to Crossover
Strip two 2-3' pieces of speaker wire and solder the ends of one wire on each of the subwoofer terminals. Connect the other end to the screw terminals labelled "subwoofer" on that channel's corresponding crossover. Make sure that you connect the + crossover output to the + speaker terminal.
Step 15: Wire Tweeters to Crossover
Since the two tweeters have a resistance of 4Ohm, I wired them in series to the tweeter output from the crossover. To do this, connect one tweeter's + lead to the + crossover terminal (you may need to lengthen the wire). Then connect the - lead of second tweeter (of the same channel) to the - crossover terminal. Connect the remaining two leads from the tweeters to each other to wire them in series. Repeat this for the second channel.
Step 16: Secure Batteries
Use small L brackets to secure the two batteries against the lower corners of the suitcase.
Step 17: Prepare Amplifier Power Cable
Cut the power supply that came with the amplifier and strip the wire. The outside lead is - and the inside lead is +. Connect the exposed leads to a piece of 1-2' speaker wire and cover the connection with electrical tape. This wire will connect the amplifier to the charge controller.
Step 18: Prepare Battery Terminal Clips
Cut two more pieces of 1-2' speaker wire and crimp a 3/16" quick disconnect connector on one end of each wire. These wires will connect the batteries to the charge controller.
Step 19: Connections to Charge Controller "battery" Terminals
Connect the + end of the two battery connections from the last step, and the amplifier power supply wire and crimp with one of the terminals included with the charge controller. Do the same for the - leads of these three wires. Screw the terminal connections to the + and - terminals of the charge controller, on the side labelled "battery".
Step 20: Wire Charge Controller to Batteries
Connect the quick disconnects from the charge controller to the batteries. Make sure to connect the + from the charge controller to the + on the battery (and vice versa).
Step 21: Prepare External Power Supply Cable
Cut a 1-2' piece of speaker wire and attach an M-type barrel plug to one end. Crimp the remaining two terminal mounts from the charge controller to the other end of the wire. Then screw the terminals onto the side of the charge controller labelled "array".
Step 22: Mount Charge Controller
Now that all the connections to the charge controller have been made, use wood glue and a screw to mount two pieces of 2" wood block to the plywood panel. Once the wood glue is dry, use screws to attach the charge controller to the front of these blocks.
Step 23: Remove Amplifier Front Panel
Use a hex key to remove the four corners screws on the front panel of the amplifier. Use a tiny hex key to loosen the set screw from the knob, and remove the knob from the panel. then use pliers to unscrew the nut attached to the knob's underlying potentiometer. The front panel should come off easily.
Step 24: Mount Amplifier
Use a pencil to mark the place on the enclosure where you would like to mount your amplifier's front panel. I mounted mine on the side of my suitcase. Drill out holes for the 4 corner screws, potentiometer, switch, and blue LEDs.
My suitcase enclosure added about 1/2" of extra space between the front panel and the rest of the amplifier. Since the original screws weren't long enough to cover this distance, I went to the hardware store and found some ~1.25" 3mm screws to replace them.
Screw through the suitcase enclosure to mount the front panel on the amplifier. The amplifier is light enough that it will support itself by the screws alone.
Step 25: Connect Charge Controller to Amplifier
Make sure the amplifier is switched to the off position and plug in the connection from the charge controller.
Step 26: Mount External Power Supply Jack
Drill a hole in the suitcase and mount the M-type barrel plug. My enclosure's walls were so thick that I couldn't use a nut to lock the plug in place, I supplemented with super glue. You can use the 12V wall wart or even a 12V solar panel to trickle charge your batteries through this jack.
Step 27: Connect RCA Cable to Amplifier
Plug the red and white ends of the RCA cable to the amplifier input.
Step 28: Mount External Audio Jack to Suitcase
In case you want to access the audio in from the outside of the case, mount an 1/8" stereo jack to the side of the suitcase. Use some 22 gauge wire to connect the leads from the jack to an inline female 1/8" stereo jack. Use electrical tape to cover any exposed solder points.
This way, you can store your audio devices inside the suitcase by plugging them directly to the 1/8" stereo jack to RCA cable that is plugged directly into the amplifier. Or you can plug the 1/8" stereo/RCA cable into the inline jack, and use a male to male stereo cable to hook up to the external 1/8" jack.
Step 29: Create IPod/phone Mount on Inside of Suitcase
To make thing really fancy, I used some of the extra fabric I removed in step 2, to create a little pocket for holding my phone/iPod inside the suitcase.
Step 30: Rock Out
You're done! Have fun! Be sure to check the voltage readout on the charge controller occasionally and make sure the battery doesn't get too drained (the charge controller won't be able to charge the batteries if they are completely drained).
______
Cookie preferences
Your privacy is important to us and so is an optimal experience. To help us customize information and build applications, we collect data about your use of this site.
Learn more about the Third-Party Services we use in each category, and how we use the data we collect from you online.
Strictly necessary – required for our site to work and to provide services to you
Qualtrics
We use Qualtrics to let you give us feedback via surveys or online forms. You may be randomly selected to participate in a survey, or you can actively decide to give us feedback. We collect data to better understand what actions you took before filling out a survey. This helps us troubleshoot issues you may have experienced. Qualtrics Privacy Policy
Akamai mPulse
We use Akamai mPulse to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Akamai mPulse Privacy Policy
Digital River
We use Digital River to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Digital River Privacy Policy
Dynatrace
We use Dynatrace to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Dynatrace Privacy Policy
Khoros
We use Khoros to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Khoros Privacy Policy
Launch Darkly
We use Launch Darkly to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Launch Darkly Privacy Policy
New Relic
We use New Relic to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. New Relic Privacy Policy
Salesforce Live Agent
We use Salesforce Live Agent to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Salesforce Live Agent Privacy Policy
Wistia
We use Wistia to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Wistia Privacy Policy
Tealium
We use Tealium to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Tealium Privacy Policy
Upsellit
We use Upsellit to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Upsellit Privacy Policy
CJ Affiliates
We use CJ Affiliates to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. CJ Affiliates Privacy Policy
Commission Factory
We use Commission Factory to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Commission Factory Privacy Policy
Google Analytics (Strictly Necessary)
We use Google Analytics (Strictly Necessary) to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Google Analytics (Strictly Necessary) Privacy Policy
Typepad Stats
We use Typepad Stats to collect data about your behaviour on our sites. This may include pages you’ve visited. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our platform to provide the most relevant content. This allows us to enhance your overall user experience. Typepad Stats Privacy Policy
Geo Targetly
We use Geo Targetly to direct website visitors to the most appropriate web page and/or serve tailored content based on their location. Geo Targetly uses the IP address of a website visitor to determine the approximate location of the visitor’s device. This helps ensure that the visitor views content in their (most likely) local language.Geo Targetly Privacy Policy
SpeedCurve
We use SpeedCurve to monitor and measure the performance of your website experience by measuring web page load times as well as the responsiveness of subsequent elements such as images, scripts, and text.SpeedCurve Privacy Policy
Qualified
Qualified is the Autodesk Live Chat agent platform. This platform provides services to allow our customers to communicate in real-time with Autodesk support. We may collect unique ID for specific browser sessions during a chat. Qualified Privacy Policy
Improve your experience – allows us to show you what is relevant to you
Google Optimize
We use Google Optimize to test new features on our sites and customize your experience of these features. To do this, we collect behavioral data while you’re on our sites. This data may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, your Autodesk ID, and others. You may experience a different version of our sites based on feature testing, or view personalized content based on your visitor attributes. Google Optimize Privacy Policy
ClickTale
We use ClickTale to better understand where you may encounter difficulties with our sites. We use session recording to help us see how you interact with our sites, including any elements on our pages. Your Personally Identifiable Information is masked and is not collected. ClickTale Privacy Policy
OneSignal
We use OneSignal to deploy digital advertising on sites supported by OneSignal. Ads are based on both OneSignal data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that OneSignal has collected from you. We use the data that we provide to OneSignal to better customize your digital advertising experience and present you with more relevant ads. OneSignal Privacy Policy
Optimizely
We use Optimizely to test new features on our sites and customize your experience of these features. To do this, we collect behavioral data while you’re on our sites. This data may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, your Autodesk ID, and others. You may experience a different version of our sites based on feature testing, or view personalized content based on your visitor attributes. Optimizely Privacy Policy
Amplitude
We use Amplitude to test new features on our sites and customize your experience of these features. To do this, we collect behavioral data while you’re on our sites. This data may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, your Autodesk ID, and others. You may experience a different version of our sites based on feature testing, or view personalized content based on your visitor attributes. Amplitude Privacy Policy
Snowplow
We use Snowplow to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Snowplow Privacy Policy
UserVoice
We use UserVoice to collect data about your behaviour on our sites. This may include pages you’ve visited. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our platform to provide the most relevant content. This allows us to enhance your overall user experience. UserVoice Privacy Policy
Clearbit
Clearbit allows real-time data enrichment to provide a personalized and relevant experience to our customers. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID.Clearbit Privacy Policy
YouTube
YouTube is a video sharing platform which allows users to view and share embedded videos on our websites. YouTube provides viewership metrics on video performance. YouTube Privacy Policy
Customize your advertising – permits us to offer targeted advertising to you
Adobe Analytics
We use Adobe Analytics to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, and your Autodesk ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Adobe Analytics Privacy Policy
Google Analytics (Web Analytics)
We use Google Analytics (Web Analytics) to collect data about your behavior on our sites. This may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. We use this data to measure our site performance and evaluate the ease of your online experience, so we can enhance our features. We also use advanced analytics methods to optimize your experience with email, customer support, and sales. Google Analytics (Web Analytics) Privacy Policy
AdWords
We use AdWords to deploy digital advertising on sites supported by AdWords. Ads are based on both AdWords data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that AdWords has collected from you. We use the data that we provide to AdWords to better customize your digital advertising experience and present you with more relevant ads. AdWords Privacy Policy
Marketo
We use Marketo to send you more timely and relevant email content. To do this, we collect data about your online behavior and your interaction with the emails we send. Data collected may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, email open rates, links clicked, and others. We may combine this data with data collected from other sources to offer you improved sales or customer service experiences, as well as more relevant content based on advanced analytics processing. Marketo Privacy Policy
Doubleclick
We use Doubleclick to deploy digital advertising on sites supported by Doubleclick. Ads are based on both Doubleclick data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Doubleclick has collected from you. We use the data that we provide to Doubleclick to better customize your digital advertising experience and present you with more relevant ads. Doubleclick Privacy Policy
HubSpot
We use HubSpot to send you more timely and relevant email content. To do this, we collect data about your online behavior and your interaction with the emails we send. Data collected may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, email open rates, links clicked, and others. HubSpot Privacy Policy
Twitter
We use Twitter to deploy digital advertising on sites supported by Twitter. Ads are based on both Twitter data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Twitter has collected from you. We use the data that we provide to Twitter to better customize your digital advertising experience and present you with more relevant ads. Twitter Privacy Policy
Facebook
We use Facebook to deploy digital advertising on sites supported by Facebook. Ads are based on both Facebook data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Facebook has collected from you. We use the data that we provide to Facebook to better customize your digital advertising experience and present you with more relevant ads. Facebook Privacy Policy
LinkedIn
We use LinkedIn to deploy digital advertising on sites supported by LinkedIn. Ads are based on both LinkedIn data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that LinkedIn has collected from you. We use the data that we provide to LinkedIn to better customize your digital advertising experience and present you with more relevant ads. LinkedIn Privacy Policy
Yahoo! Japan
We use Yahoo! Japan to deploy digital advertising on sites supported by Yahoo! Japan. Ads are based on both Yahoo! Japan data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Yahoo! Japan has collected from you. We use the data that we provide to Yahoo! Japan to better customize your digital advertising experience and present you with more relevant ads. Yahoo! Japan Privacy Policy
Naver
We use Naver to deploy digital advertising on sites supported by Naver. Ads are based on both Naver data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Naver has collected from you. We use the data that we provide to Naver to better customize your digital advertising experience and present you with more relevant ads. Naver Privacy Policy
Quantcast
We use Quantcast to deploy digital advertising on sites supported by Quantcast. Ads are based on both Quantcast data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Quantcast has collected from you. We use the data that we provide to Quantcast to better customize your digital advertising experience and present you with more relevant ads. Quantcast Privacy Policy
Call Tracking
We use Call Tracking to provide customized phone numbers for our campaigns. This gives you faster access to our agents and helps us more accurately evaluate our performance. We may collect data about your behavior on our sites based on the phone number provided. Call Tracking Privacy Policy
Wunderkind
We use Wunderkind to deploy digital advertising on sites supported by Wunderkind. Ads are based on both Wunderkind data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Wunderkind has collected from you. We use the data that we provide to Wunderkind to better customize your digital advertising experience and present you with more relevant ads. Wunderkind Privacy Policy
ADC Media
We use ADC Media to deploy digital advertising on sites supported by ADC Media. Ads are based on both ADC Media data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that ADC Media has collected from you. We use the data that we provide to ADC Media to better customize your digital advertising experience and present you with more relevant ads. ADC Media Privacy Policy
AgrantSEM
We use AgrantSEM to deploy digital advertising on sites supported by AgrantSEM. Ads are based on both AgrantSEM data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that AgrantSEM has collected from you. We use the data that we provide to AgrantSEM to better customize your digital advertising experience and present you with more relevant ads. AgrantSEM Privacy Policy
Bidtellect
We use Bidtellect to deploy digital advertising on sites supported by Bidtellect. Ads are based on both Bidtellect data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Bidtellect has collected from you. We use the data that we provide to Bidtellect to better customize your digital advertising experience and present you with more relevant ads. Bidtellect Privacy Policy
Bing
We use Bing to deploy digital advertising on sites supported by Bing. Ads are based on both Bing data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Bing has collected from you. We use the data that we provide to Bing to better customize your digital advertising experience and present you with more relevant ads. Bing Privacy Policy
G2Crowd
We use G2Crowd to deploy digital advertising on sites supported by G2Crowd. Ads are based on both G2Crowd data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that G2Crowd has collected from you. We use the data that we provide to G2Crowd to better customize your digital advertising experience and present you with more relevant ads. G2Crowd Privacy Policy
NMPI Display
We use NMPI Display to deploy digital advertising on sites supported by NMPI Display. Ads are based on both NMPI Display data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that NMPI Display has collected from you. We use the data that we provide to NMPI Display to better customize your digital advertising experience and present you with more relevant ads. NMPI Display Privacy Policy
VK
We use VK to deploy digital advertising on sites supported by VK. Ads are based on both VK data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that VK has collected from you. We use the data that we provide to VK to better customize your digital advertising experience and present you with more relevant ads. VK Privacy Policy
Adobe Target
We use Adobe Target to test new features on our sites and customize your experience of these features. To do this, we collect behavioral data while you’re on our sites. This data may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, your IP address or device ID, your Autodesk ID, and others. You may experience a different version of our sites based on feature testing, or view personalized content based on your visitor attributes. Adobe Target Privacy Policy
Google Analytics (Advertising)
We use Google Analytics (Advertising) to deploy digital advertising on sites supported by Google Analytics (Advertising). Ads are based on both Google Analytics (Advertising) data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Google Analytics (Advertising) has collected from you. We use the data that we provide to Google Analytics (Advertising) to better customize your digital advertising experience and present you with more relevant ads. Google Analytics (Advertising) Privacy Policy
Trendkite
We use Trendkite to deploy digital advertising on sites supported by Trendkite. Ads are based on both Trendkite data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Trendkite has collected from you. We use the data that we provide to Trendkite to better customize your digital advertising experience and present you with more relevant ads. Trendkite Privacy Policy
Hotjar
We use Hotjar to deploy digital advertising on sites supported by Hotjar. Ads are based on both Hotjar data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Hotjar has collected from you. We use the data that we provide to Hotjar to better customize your digital advertising experience and present you with more relevant ads. Hotjar Privacy Policy
6 Sense
We use 6 Sense to deploy digital advertising on sites supported by 6 Sense. Ads are based on both 6 Sense data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that 6 Sense has collected from you. We use the data that we provide to 6 Sense to better customize your digital advertising experience and present you with more relevant ads. 6 Sense Privacy Policy
Terminus
We use Terminus to deploy digital advertising on sites supported by Terminus. Ads are based on both Terminus data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that Terminus has collected from you. We use the data that we provide to Terminus to better customize your digital advertising experience and present you with more relevant ads. Terminus Privacy Policy
StackAdapt
We use StackAdapt to deploy digital advertising on sites supported by StackAdapt. Ads are based on both StackAdapt data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that StackAdapt has collected from you. We use the data that we provide to StackAdapt to better customize your digital advertising experience and present you with more relevant ads. StackAdapt Privacy Policy
The Trade Desk
We use The Trade Desk to deploy digital advertising on sites supported by The Trade Desk. Ads are based on both The Trade Desk data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that The Trade Desk has collected from you. We use the data that we provide to The Trade Desk to better customize your digital advertising experience and present you with more relevant ads. The Trade Desk Privacy Policy
RollWorks
We use RollWorks to deploy digital advertising on sites supported by RollWorks. Ads are based on both RollWorks data and behavioral data that we collect while you’re on our sites. The data we collect may include pages you’ve visited, trials you’ve initiated, videos you’ve played, purchases you’ve made, and your IP address or device ID. This information may be combined with data that RollWorks has collected from you. We use the data that we provide to RollWorks to better customize your digital advertising experience and present you with more relevant ads. RollWorks Privacy Policy
Are you sure you want a less customized experience?
We can access your data only if you select "yes" for the categories on the previous screen. This lets us tailor our marketing so that it's more relevant for you. You can change your settings at any time by visiting our privacy statement
Your experience. Your choice.
We care about your privacy. The data we collect helps us understand how you use our products, what information you might be interested in, and what we can improve to make your engagement with Autodesk more rewarding.
May we collect and use your data to tailor your experience?
Explore the benefits of a customized experience by managing your privacy settings for this site or visit our Privacy Statement to learn more about your options.
