Introduction: Survival Tee Shirt
Introduction
A Survival Tee Shirt (STS) is a must have in your BOB, 72 Hour Bag, when Back Packing, Camping and stashed in your vehicle. This is one multipurpose piece of equipment. It is more than just a piece of clothing, other applications are as a Covering, Medical, Travel and Filtering/Cooking.
What is special with this tee shirt to elevate its status to a survival designation? That is a good question. The answer will become more clear throughout this instructable. First let’s choose the best tee shirt. Look for one that is roomy, has long sleeves and is light in color.
Up Next Choosing the Survival Tee Shirt
Note: This instructable is for education purposes.
Step 1: The Tee Shirt
XL or XXL Long Sleeve Tee Shirt
XL or XXL. Choose a size 1 to 2 times bigger than you. The reason for a larger size, it is easy to wear over other clothing, loose fit when wearing in the heat or cold.
LongSleeves are more versatile than short sleeves. Long sleeves are handy when the weather turns cool or cold, to keep your wrists and hands covered. You can roll the sleeves up or down 1/4, 1/2, 3/4 even up to the shoulder, that is not something you can do with short sleeves. Long sleeves tie nice when making a Bag or Sling.
Light Color to reduce solar absorption. This is beneficial when covering your face and head and body.
Up Next STS Head Covering
Step 2: Head Covering
Protect against Sun, Cold and Dust. This can be worn over the head or as an extra layer over the body.
1) From inside the STS place your face at the opening of the neck, not through it.
2) Take the sleeves and pull them back around your head.
3) The opening of the neck will fold up over your mouth and nose.
4) Tie the sleeves behind your head with a square knot.
5) Drape the remaining shirt over your shoulders.
Up Next STS Sling
Step 3: Medical
Can be used as a Sling or cut up for Bandage Wraps.
1) Fold your STS vertical so the sleeves line up.
2) Tie the sleeves in a square knot.
3) Take the bottom corners and tie them together in a double square knot.
4) Place the STS Sling over the head of the injured person and slide in the arm.
For Bandage Wraps
1) Cut 1 - 2 inches from the bottom of the shirt at the waist.
2) Cut the band in half.
3) Tie around the injury.
4) Cut off excess and save for another time.
Your STS is long enough that you still will have plenty left for other uses.
Up Next STS Bag
Step 4: Travel - Bag
This STS Bag can be used vertically or horizontally. Which means you can place items vertically inside the body of the tee shirt, through the neck opening, or horizontally as you did with your arm for the STS Sling.
4) Place the STS Bag over your head.
5) Place the items inside your STS Bag.
Up Next STS Pillow
Step 5: Travel - Pillow
Your Survival Tee Shirt rolls or folds up nicely to place under you head. Because of the extra large size of your STS you have a thicker or more padded STS Pillow.
Great to use in your car, on the ground when ever you want a padded place to rest you head.
Up Next STS Towel
Step 6: Towel
Your STS Towel is wide and long. This STS is 23 inches wide by 29 inches long also being 2 ply.
You can wet your STS and wrap it around your neck or over your head to cool off.
It will absorb a lot of water and dry quickly in the sun, near your campfire or hanging in the breeze.
Up Next STS Water Filter
Step 7: Water Filter
I dumped a couple of tea bags in to water, let them soak for a few minutes to illustrate how to use your STS Water Filter. This will filter out large debris and small floaties or sediment. Before drinking treat water by boiling or chemical.
1) Place your STS over the opening of the bottle or container.
2) Hold the STS tight with your hand or tie off.
3) Place the bottle into the source water.
4) Squeeze the bottle to remove the air, creating negative pressure inside the bottle.
5) Release the external pressure from the bottle so the water will be pulled inside through the STS Filter restoring equilibrium again.
6) Repeat Steps 4 and 5 until you have enough water.
7) Remove the bottle from the water source and remove the STS Filter.
8) Boil or treat water.
9) Drink, use for cooking or washing.
Up Next Observations and Summary
Step 8: Observations & Summary
Observations
The benefits of your STS are:
1) Inexpensive and easy to use.
2) Light weight and does not take up much space.
3) Multiple applications from 1 tee shirt.
4) Essential for Survival and Comfort while away from home.
What are you waiting for? Go and pick up your STS.
Summary
I am satisfied with the results.
Hear advice, and receive instruction, so that you may be wise in your latter end.
