Introduction: Timekeeping on ESP8266 & Arduino Uno WITHOUT an RTC (Real Time CLock)?
Step 1: PRO's and Cons of RTC Units
As an electronics, IOT and pyro enthousiast, I do a lot of projects that involve time keeping. Conventional wisdom on instructables and other tutorial sites is that for accurate time keeping, you need an RTC unit (see pic, click here to read more on RTC's). An RTC (Real time clock) is a seperate chip with a battery that keeps track of time for years.
The pros are clear:
- Time keeping is really precise
- RTC's have their own battery and remember time even when your project is powered off
- RTC's keep track of time even when your arduino crashes or gets reset
But what many instructables fail to mention is that there are also a lot of cons and "meh"s:
- You lose two pins you could have used for something else, when working with esp8266 based boards this really matters
- You need to buy yet another part and wait for it to ship. It can easily delay your project if you order from the far east
- RTC's are relatively bulky. I do most of my projects in 10 x 4 x 6 cm x cases. The RTC does NOT fit.
- It's extra work: you need to solder it, program it seperately. install libraries, cram it in your project.
- when you open the serial monitor, the RTC resets in the basic time set program, a nuissance
- Many of them are not that precise either, the cheaper ones are known to be off several seconds a day, source
- Most RTC libraries and instructables used here do NOT include code to change time back/from day light savings, meaning you have to manually reset time every six months anyways.
Step 2: THE ACTUAL TEST: How Accurate Is an Arduino Uno / ESP8266 Without RTC?
"But the arduino uno / ESP8266 / Wemos is inaccurate without RTC and I need accuracy above all else!" - says the skeptic. Almost all arduino clock instructables therefore feature an RTC unit, even if they are never going to be switched off and dont require the back up function.
Well I was skeptic too. But I was frustrated with complexly coded internet applications, bulky RTC units , librairies that werent universally compatible, and frustrated with the sloppyness of it all. So I wrote my own sketch to keep time that will work on ANY arduino compatible microcontroller. The sketch is based only on the millis() function. This function works on any microcontroller and all it does is count the milliseconds that have elapsed since your last reset. You will find the sketch below including comments explaing everything and I also attached it to this instructable in a seperate .ino file. It is dirt simple to make if you follow my comments and you will easily be able to make your own custom version based on your time keeping needs:
//Written by Ruben Marc Speybrouck
unsigned long timeNow = 0;
unsigned long timeLast = 0;
//Time start Settings:
int startingHour = 12;
// set your starting hour here, not below at int hour. This ensures accurate daily correction of time
int seconds = 0;
int minutes = 33;
int hours = startingHour;
int days = 0;
//Accuracy settings
int dailyErrorFast = 0; // set the average number of milliseconds your microcontroller's time is fast on a daily basis
int dailyErrorBehind = 0; // set the average number of milliseconds your microcontroller's time is behind on a daily basis
int correctedToday = 1; // do not change this variable, one means that the time has already been corrected today for the error in your boards crystal. This is true for the first day because you just set the time when you uploaded the sketch.
void setup() { // put your setup code here, to run once:
Serial.begin(9600); }
void loop() { // put your main code here, to run repeatedly:
timeNow = millis()/1000; // the number of milliseconds that have passed since boot
seconds = timeNow - timeLast;
//the number of seconds that have passed since the last time 60 seconds was reached.
if (seconds == 60) {
timeLast = timeNow;
minutes = minutes + 1; }
//if one minute has passed, start counting milliseconds from zero again and add one minute to the clock.
if (minutes == 60){
minutes = 0;
hours = hours + 1; }
// if one hour has passed, start counting minutes from zero and add one hour to the clock
if (hours == 24){
hours = 0;
days = days + 1;
//if 24 hours have passed, add one day
if (hours ==(24 - startingHour) && correctedToday == 0){
delay(dailyErrorFast*1000);
seconds = seconds + dailyErrorBehind;
correctedToday = 1; }
//every time 24 hours have passed since the initial starting time and it has not been reset this day before, add milliseconds or delay the program with some milliseconds.
//Change these varialbes according to the error of your board.
// The only way to find out how far off your boards internal clock is, is by uploading this sketch at exactly the same time as the real time, letting it run for a few days
// and then determining how many seconds slow/fast your boards internal clock is on a daily average. (24 hours).
if (hours == 24 - startingHour + 2) {
correctedToday = 0; }
//let the sketch know that a new day has started for what concerns correction, if this line was not here the arduiono // would continue to correct for an entire hour that is 24 - startingHour.
Serial.print("The time is: ");
Serial.print(days);
Serial.print(":");
Serial.print(hours);
Serial.print(":");
Serial.print(minutes);
Serial.print(":");
Serial.println(seconds);
I ran the code on both a wemos D1 and an arduino uno. I set the time equal with the time from:http://www.timeanddate.com/ on midnight day zero (you obviously dont have to start at midnight! - I included time set code above void setup). After one day and 9 hours the difference between the time on my microcontrollers and this website was about one second. I checked this by taking a screenshot of my serial monitor on one side of the screen and having the webpage open on the other side. (see pic).
After about 3 days, on both my arduino and wemos the clock was about 2 to 2,5 sec fast. that is 274 seconds a year off or just over four and a half minutes. That's unacceptable!!! No, not really. I just added a line of code to my sketch that corrects the time on my microcontrollers either by delaying the program just a little every 24 hours or by adding a few milliseconds every day. In my case about 0,75 seconds every day. And there you have it, long term near second precise timekeeping with no fuss on any board!
Here is the correction code all together in practice once again so you could easily see the whole picture
//Accuracy settings
int dailyErrorFast = 0; // set the average number of milliseconds your microcontroller's time is fast on a daily basis int dailyErrorBehind = 0; // set the average number of milliseconds your microcontroller's time is behind on a daily basis int correctedToday = 1; // do not change this variable, one means that the time has already been corrected today for the error in your boards crystal. This is true for the first day because you just set the time when you uploaded the sketch.:
seconds = seconds + dailyErrorBehind; correctedToday = 1; }
//every time 24 hours have passed since the initial starting time and it has not been reset this day before)
if (hours == 24 - startingHour + 2) { correctedToday = 0; }
Step 3: Conclusion: You Just Dont Need an RTC, Seriously.
You only need an RTC if you are going to keep track of time while your device is switched off completely. Otherwise using an RTC is a huge HASSLE WITHOUT ANY added value. The ESP8266, arduino uno and most likely many other boards are perfectly capable of keeping track of time all on their own. What inaccuracies they do have can easily be corrected through my sketch by adding / reducing a few milliseconds every 24 hour hours.
Get out there, build clocks, dont waste time and money where you dont have to!
Oh, and please check out my other instructables and vote for me if you liked this one ;)
