Introduction: TV Stand Pallet
Easy rustic tv stand that you can make almost for free :) perfect for someone who has a 32 inch tv.
Step 1: Getting the Idea of It
So I decided to take the pallet home and make it into a tv stand, so when I put the pallet down and stuck my tv on top of it, and guess what? It fitted bang on :) Tools L bracket, Colron cloth, Colron wood dye victorian pine, B&Q value sandpaper 15 Assorted sheets, small brush for corners and gaps, one pallet, and two wooden fence post.
Step 2: Planning.
So if the look at the planks there are 11 in total it's great that they fit in the middle of the stand..yes OCD. I also found some fence post which was used for the Shower support unit, basically make sure your plumier isn't a cowboy.
Step 3: Using the Fence Post As Legs
Now I wanted the fence post to be legs for the tv stand just to give it a bit of height.
Step 4: Final Idea Done
So this is what I wanted to look, the post I the middle just half a foot out under the pallet, I like it already :)
Step 5: Sanding
So I went to B&Q got my sanding paper that was 15 in a pack great.
Step 6: 60 Grit
Sanding block is always good to use so I started sanding the pallet down with 60 grit sandpaper. Oh and one thing that was a happy accident it rained over night so I wanted to sand it straight away, so I did. And it was really smooth even when it was dry.
Step 7: 100 Grit
So I added teak oil to the pallet and waited for it to soak over night and sanded it with 100 grit which made so smooth, I went against the grain in up and down motion doing that to every single plank. After the sanding I went went for the dye not stain I want to see the grain which will give me a better result.
Step 8: The Dye
I didn't have to add layers and layers of dye I used a stain clothe which is the same as the dye, by the way dye was victorian pine which I recommend strongly.
Step 9: Result
Step 10: Final Stage
All dyed and loved.
Step 11: Bracket
I added a bracket behind the legs of the stand for the final Touch. It is optional to use if you want to you to bracket.
Step 12: Oh and This Is Optional
You can use another fence post behind the front leg so yo can put an xbox books DVD players what every you want :) thank you for reading and I hope this gives people something to do it was fun and easy to make.
