Introduction: TimeFrame - a Time Portal to Put on Your Desk.
Mind-blowing gadgets are rare these days. Very seldom will you stumble across something truly magical that leaves you in a state of confusion and amazement
This project is inspired by water drop levitating installations such as shown by many museums around the world and the “Slow Dance” kickstarter campaign by Jeff Lieberman.
http://www.kickstarter.com/projects/xercyn/slow-dance-a-frame-that-slows-down-time
What do you need to build your own?
You can get the kit including all parts here: http://www.cubic-print.com/TimeFrame
Get latest software here: http://www.github.com/cubic-print/timeframe
Tools:
  • Soldering stuff
  • Battery-powered screw gun
  • Various drill bits(2mm, 3mm, 6mm)
  • Pliers & wire cutter
  • Mini USB-B cable for programming the Arduino
Frame:
  • 1x 12V 1A power supply
  • 1x picture frame (at least 25mm deep, better 35mm)
  • 2m LED stripes (3 pieces of 60cm each)
  • 1x thin metal plate like thickness metal gauge (thickness: 0.3mm size: 10x70mm)
  • 1x rod fixation plate (eg. Aluminum 20x55x2mm)
  • 1x wood block about 4 mm longer than the iron core
  • 3x wood screws + washers
  • 1x iron rod / screw / nail (length around 60mm diameter: 6-12mm)
  • 1x fixation for iron rod like M6 bolt or just a nut in case you use iron screw
  • 45m (=40gr) 0.41mm (AWG26) isolated cooper wire
  • 3x small Neodym magnet (d=10 h=2)
Electronics
  • 1x Atmega Nano V3.0 328P
  • 1x Capacitor 16V 4200 uF
  • 2x Mosfet IRF540N
  • 2x 10K Resistor
  • 2x 300 Ohm Resistor
  • 2x Diodes 1N4007
  • some cables for LED connection
Step 1: Preparing the Coil
Step 2: Mount the LEDs in the Frame
Step 3: Assemble Central Wood Block
Step 4: Build the Electronics and Mount the PCB
Please note that below circuit can not be simulated at the moment. The interrupt implementation is missing in the emulator software. Also Arduino Mini instead of suggested Nano has been used.
Programm the attached INO file or get latest software here: http://www.github.com/cubic-print/timeframe
Do not connect the unit to a computer when the magnetic coil is connected. The current draw and the reversed induced voltage might damage your USB port or computer. Always remove the Arduino from the PCB for programming!
Below video shows the kit electronic assembly.
Step 5: Operation and Dangers
Flowers and leaves work best. Please make sure they are dry so that the metal base is not rusting. Feathers also look truly amazing. Not sustainable enough? Paper-Flowers work as well. These can be a bit noisier depending upon material used.
Just use a rubber band to fix the flower on top of the resonator plate. For thin flowers you can also use a magnet to squeeze it in. The included magnets serve two purposes. They enhance the magnetic force and balance the momentum of the whole resonator. The amount and position is greatly influences the noise and amplitude of the movement.
All magnets have a north and south pole. They will better work in one or the other orientation depending on your coil winding direction. Just try were you think they offer more clamping force towards the running resonator plate.
The strongest force you get with the magnets opposite of the coil.
To increase the force even further you can put one magnet dictly on the end of the iron core of the electro magnet and not on the resonator plate. If you want to lower to force you can move the magnets up/down as well. This works especially well if you have only a small flower with low momentum it often makes sense to use less magnets, but move at least one magnet up where the flower is attached. This increases the tip weight and will remove any fast jitter from the movement.
Danger
The high frequency flickering within this product may cause an epileptic reaction due to photosensitivity. Most people will not even realize the flickering because it is much faster than average computer monitor. Due to uncertainties regarding the epileptic nature of this product please stop looking into the light when you experience other symptoms like headache, nausea or dizziness. Be especially careful during programming. Anything lower than 50 Hz will look like the strobe lights in a nightclub.
