Introduction: Traffic Light ,9 Led Using Arduino Uno
Materials required:
1. 3 red led, 3 yellow led, 3 green led
2. Breadboard
3. Arduino UNO
4. Cable
5. Arduino IDE on PC
6. Connecting wires
Summary of project:
This project is making a simple traffic light but helps in understanding Arduino basics. Basically there are 3 traffic lights with 9 leds that light up according to turn. In this project you will learn:
- Using digital output pins
- Using the Arduino IDE
- Uploading code on the Arduino
- and most important of all make a project yourself
Step 1: Step 2 :Make Connections
- Connect the red, yelow, green,red, yelow, green, red, yelow, green leds to pins 2,3,4,5,6,7,8,9,10 of Arduino respectively . (connect longer ends of the led)
- Connect the shorter side of the led to ground and the longer side to the output pins and then connect it to the GND pin on the Arduino
- Connect the Arduino to the PC and download the software if not present already (from www.ardunio.cc)
- Open the arduino programmer go to tools> board and select "Arduino Uno"
- Next go to tools> serial port and select appropriate port to which Arduino is connected
- Next click file>new and paste the code below
//CODE BY OMAR ADIL
int led2 = 2;
int led3 = 3;
int del=1000;
int led4 = 4;
int led5 = 5;
int led6 = 6;
int led7 = 7;
//CODE BY OMAR ADIL
int led8 = 8;
int led9 = 9;
int led10 =10;
// the setup routine runs once when you press reset:
void setup() {
// initialize the digital pin as an output.
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
pinMode(led7, OUTPUT);
pinMode(led8, OUTPUT);
pinMode(led9, OUTPUT);
pinMode(led10, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
digitalWrite(led2, HIGH);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
digitalWrite(led5, HIGH);
digitalWrite(led6, LOW);
digitalWrite(led7, LOW);
digitalWrite(led8, HIGH);
digitalWrite(led9, LOW);
digitalWrite(led10, LOW);
delay(del/2);
//ALL RED
digitalWrite(led2, LOW);
digitalWrite(led4, HIGH);
delay(2*del);
//GREEN1
digitalWrite(led3, HIGH);
delay(del);
//YELLOW1
delay(del/2);
//ALL RED
digitalWrite(led5, LOW);
digitalWrite(led7, HIGH);
delay(del*2);
//GREEN2
digitalWrite(led6, HIGH);
delay(del);
//YELLOW2
delay(del/2);
//ALL RED
digitalWrite(led8, LOW);
digitalWrite(led10, HIGH);
delay(del*2);
//GREEN 3
digitalWrite(led9, HIGH);
delay(del);
//YELLOW3
