Introduction: Turn Newspapers & Junk Mail Back Into Logs
Disclaimer: According to the Seattle Times, in the state of Washington burning rolled paper logs is illegal. There may be other locations that also have laws regarding or prohibiting burning of news paper logs. While the Seattle times states that paper logs are bad for the environment, and makes reference to their own legislature, and a vague mention of the EPA, they do not cite any sources as reference. I am not here to argue their opinion, but having said this, it is upon you, that if you should decide to participate in the process of rolling your own logs to burn for whatever your reason, you should ensure that you will not run afoul with the local laws regarding what you can and cannot burn in your fire appliance. Whether it be an indoor fireplace or an outdoor fire pit, you should always fully educate yourself in any endeavor you take up to keep yourself and those around you safe.
This is the article for your perusal: http://community.seattletimes.nwsource.com/archive...
The purpose of this instructable is to educate you on the process of creating a paper log.
On to the project if you dare!
With today's focus on saving money, more people are turning to wood, pellet and corn stoves to heat their houses. What if instead of harassing the receiving dept's of companies with their own junk mail, or recycling your newspapers, you use them for inexpensive heating in your wood stove. Mind you I have no problem with recycling, but given the option of recycling, or keeping my family warm, I choose the later, hopefully you understand.
It's mid-spring right now, and it's the perfect time to start this project as it does take some time before the logs can be used in a wood stove for the winter. We use this method for camping every year, and it saves us the trouble of finding fire wood, or money by not having to buy precut pre-dried fire wood. The benefit is that it's virtually free, provided you value your time at zero.
Step 1: What You Will Need:
Large container for water
Cotton string or twine
Water
And some spare time
Step 2: Find the Perfect Spot to Setup Shop
Step 3: Wet Your News Print/junk Mail
Step 4: Drip Dry?
Step 5: Roll It
Step 6: Build It Bigger!
Step 7: Rinse...Repeat...forever
Step 8: Drying Time
I recommend standing the log on it's end to dry out, rather than laying it on its side.
Wet logs will not burn well, and tend to be smoky, so it's best to be sure to get them nice and dry before you use them. Setting them in a dry location that gets plenty of sun will help dry them faster.
Step 9: Final Thoughts
A final note, I advise you be somewhat selective about the kind of paper you use. Some paper like those found in magazines are coated. If this paper is burned it tends to put out a thick black smoke. I don't know what it is that the paper is coated in, but I suspect it's something to do with plastic. This would be bad for the environment, so please recycle this kind of paper.
The best kind of paper to use would be newspapers, and credit card bills(after you've paid them of course)
Here is a shot of the log dried out. An unfortunate side effect is sometimes the paper log will grow a little mold on it while it's drying. This can be seen on the side of the roll. If this kind of thing bothers you, then you should probably stand the roll on a suspended wire mesh, or chicken wire so that it can dry without sitting in a puddle.
