Introduction: UMD Holder
This instructable shows you how to create a lego UMD holder
Step 1: Parts
lego you need
1#base (any colour)
4# 2 by 2 thick blocks (matching colour)
2# 2 by 10 thin blocks (matching colour)
4# 1 by 2 thick blocks (matching colour)
2# 1 by 10 thin blocks (matching colour)
7# 1 by 6 thick blocks (matching colour if posible)
1# 1 by 8 thick block
4# 1 by 4 thick blocks (matching colour if possible)
1# 2 by 4slanted block
1#base (any colour)
Step 2: Base and Beginning
start with you base laid flat. Place 2 by 2 block six spaces away from other 2 by 2 block. On top of those two put 2 by 10 thin block.Do same thing 8 sp aces away.It should look like picture.
Step 3: Higher Sides and Back
place 1 by 2 thick block on 2 by 10 thin block as in pic. On top of those put 1 by 10 thin block(red in pic)
the back is made from two 1 by 6 thick blocks(I used yellow to be clear,try make the holder out of one or two colours) and the 1 by 8 thick block.Place the two (yellow in pic) 1 by 6 blocks behind and the 1 by 8 on top.(pic is seen from behind to make it easier for you to see.)
Step 4: The Insides
Facing frontwards again, place the 1 by 6 thick blocks(white in pic) 1 space apart and one space either side of block.(see pic, there are more blocks to come in but I needed to show you their place.)
Step 5: More Guts
Now for the top peices.(I have put them in grey so they stand out) Just put them on top of the insides. Simple.You can see I have put the other insides mentioned in previous pic into place.
Step 6: Last But Not Least
Put the last blocks into place, as the grey ones. then for the front.on top of the furthest forward 1 by 6 block place the 2 by 4 thick slanted block.
Step 7: Thatz It
You're done.You like it? Comments are greatfully accepted.If you think there are flaws in the design, please say.This is my first instructable.If you have more games(which I do)all you have to do is extend athe front and sides. That is the basic design.
