Introduction: Ultimate Lego Skittle Top
The skittle top I've made out of Lego's can be bounced off of walls to knock down pins. There is a video at the end of the instructions demonstrating what the top can do. You will need the following bricks: 4 three dot by three dot triangles 2 one dot by two dot rectangles 1 two dot by four dot rectangle 1 stick the length of the 2/4 rectangle 2 two dot by two dot circles 1 two dot by two dot rounded bottom circle 2 smooth one dot by one dot rectangles 2 smooth one dot by four dot rectangles 2 smooth two dot by two dot squares
Step 1: Step One
Take the four triangles and flip them over. attach the 2/4 rectangle to the center
Step 2: Step 2
Attach the 1/1 rectangles next to the 2/4 rectangle.
Step 3: Step 3
Attach the 2/2 circle to the center of the 2/4 rectangle. Attach the rounded 2/2 circle to the center 2/2 circle.
Step 4: Step 4
Flip top over and attach 2/2 circle to center of top. Attach stick to center of the 2/2 circle.
Step 5: Step 5
Attach smooth pieces around the stick and circle.
Step 6: Bonus Step
Add smooth circle to the stick.
Step 7: Play
Set up some pins and play :)
