Introduction: Vintage Inspired Valentines!
About: Hi! My name is Natalie! I have an awesome husband that lets me be a Play-at-home mom of 3! We homeschool and do projects daily! Check out my blog Doodlecraft for more awesomeness!
Make Handmade Vintage Downton Abbey inspired Valentines!
And the best part is they aren't specifically Valentine themed,
so they could be sent all year long!
Stunning with a handmade envelope too!
Step 1: Gather Inspiration
If you are a watcher of Downton Abbey,
you'll remember the season 3 episode 1...
we are dealing with the grief of passing loved ones and then it is
Saint Valentine's Day, as Mr. Carson reminds Ms. Hughes.
Anna gets one...As does Mr. Bates...from secret admirers which is no more than they deserve.
Ivy gets one...it's cute and heart shaped...and we find out later it's from Alfred.
Lastly, in the pile of bills, Mr. Carson finds one for Daisy.
And Daisy's Valentine is beautiful and brightens her day...
and she wants it to be from Alfred.
Even though, it turns out to be from Mrs. Patmore.
I zoomed in on it, so you could see that this is the vintage Valentine style I chose to mimic.
Step 2: Gather Supplies
To get started you will need:
kraft paper  (you could use brown paper bags)
Rose images printed on paper (see below)
lace, ribbon or trim
paper doilies
white lightweight paper for the envelope (not cardstock)
scissors
adhesive
mounting foam
And optional:
paper cutter, scoring board, fancy edged scissors, ticket corner punch
I wanted to be able to cut out 2 envelopes on 1 sheet of paper,
so the measurements for the cards are:
3 1/2 inches by 5 1/2"  (folded in half)
Cut the kraft paper into 5 1/2 by 7 inches.
The cards are scored down the center and folded.
This part gives a sharp creased edge, but is not necessary.
Step 3: Phase 1: Decorate!
Now is the fun part.
Decorating the cards with scraps of ribbon, lace, and trim.
You could even add a bow!
I used a paper doily piece on each card.
I love the vintage look of doilies and lace.
I used double sided tape in my tape gun for adhering lace.
I also used glue dots.  Hot glue would work as well.
Add lace until you are satisfied with the phase 1 decorations...
Step 4: Phase 2: Decorate!
Part 2, you might want some hot cocoa too!
I got these awesome vintage roses from the Graphics Fairy and filled
a sheet with them...right click to save off and print for PERSONAL use only please.
I cut out the roses and used a ticket corner punch to indent
the corners like little stamp sized tickets.
You could use scissors or a regular hole punch and achieve the same look.
I put three small tabs of mounting foam on the back of the ticket
And pressed it on over the lace and doily.  And repeat!
Step 5: Envelopes!
Once satisfied with the cards, make an envelope to go with each one too!
Okay, here's the envelope template.
I has 2 wider sides and 2 narrower sides.
with little triangle notches in between.
This template should fit 2 on 1 sheet of paper.
I would print it off, and then trace it onto thicker cardboard, like a cereal box.
Then you can trace it on 1 sheet with pencil...then stack a couple more sheets underneath and cut them out.  I used a paper cutter for the basic rectangle and then scissors for the notches.
Then fold  or score at the bottom of the notches.
Fold in the 2 narrower side flaps, put some adhesive tape on them.
Fold up the bottom flap.  Awesome!
Step 6: Finish and Deliver!
Place in your card and fold down the top!
You can put a sticker to seal it, tape it...or just tie it with twine!
Deliver to your Valentine!
If you are going to mail them, I think one stamp is plenty...but to make sure just take
them into the post office and make sure they have enough postage.  They are small, but thick.
And these would go great with flowers and chocolates too!
Hope you are inspired to make vintage Valentine's!
Check out my blog Doodlecraft for more fun, and please vote for me!
