Introduction: Custom Wall Tool Holders
About: Hello there! Thanks for stopping by! I'm Elias and I'm addicted to Making, Building and Creating any kind of things, producing free DIY videos and showing you How it's done, step by step! Here you can see some…
In this instructable you'll see: How I made some holders, over my workbench, on a big piece of melamine, for some of my hand tools.
Step 1:
I made these two same holders for my T-Handle Torx/Hex keys, Nut Drivers, Rasps and Screwdrivers.
Step 2:
I placed them down to calculate the space I need to let, between every tool, in order to find the right length of the wood.
Step 3:
I marked the distances and extended them with a try square.
Step 4:
Then I started measuring the exterior diameter of every tool and at the total result I added one millimeter (half millimeter perimetrically), in order for them to get in and out more easily.
Step 5:
I did the same process for the other piece.
Step 6:
I opened all the holes needed to both pieces very carefully, for the depth of every hole to be up to the middle of the thickness of the wood.
Step 7:
In this case the thickness of the wood is two centimeters, so I opened holes 1cm deep.
Step 8:
Now I measured the interior diameter of every tool, adding again half millimeter perimetrically, for the same reason.
Step 9:
I opened again all the holes needed for every tool but this time each hole went from one side to the other.
Step 10:
I fliped it over and marked the two abutting external lines of every circle.
Step 11:
Adjusted the blade to the right height.
Step 12:
... and I started cutting with precision until the blade touches the 2 lines I drew before.
Step 13:
Then I sanded all the sides of both pieces very well.
Step 14:
Because this is softwood and it leaves splinters on the edges, I needed to sand all the points with a soft sandpaper by hand.
Step 15:
In order the tools to come in and out more easily, I did a little rasping between the gaps.
Step 16:
After all this sanding, it’s time for painting.
Step 17:
I let them dry for one day...
Step 18:
... and then installed them on the big piece of melamine, on the wall.
Step 19:
Let’s organize this mess!
Step 20:
For the try squares I measured the thickness of every piece and made these holders.
Step 21:
For the drill bits I measured the length of the base of every set and made this holder then I put the bases of the drill bits into the holder and placed it on the wall!
Step 22:
For the holesaws I took a piece of wood some dowels and I opened 45 degree holes, in order to keep the holesaws in place.
Step 23:
Hex / Allen Keys, T-Handle Hex Keys, Forstners, Woodboring Bits, Countersink Bits, Rotary Rasp Bits, Metal Cutter Drill Bits, Chamfer Milling Cutter Drill Bits, Deburring Bits & Router Bits
Step 24:
Thanks for reading & I hope you liked it!
Subscribe, to help me make more!
https://www.youtube.com/subscription_center?add_us...
