Introduction: Wallet Made From a Wall Outlet
This wallet is made from the casing of a wall outlet. It can hold cash, a memory stick and even has two led lights.
Step 1: Gather Materials
For this wallet you will need:
- Three or four anti-static bags
-The outside plating of two wall outlets
-Tape
-Scissors
(optional)- a memory stick with the case it came in.
-Two leds
-Some thin gage wire
-Hearing aid betteries
-Switch
-Tape
-Scissors
-Two leds
-Switch
Step 2: Create Shell
The first thing you will need to do is to tape the two outlet casings together. Make sure the edges are flush with one another and that the wallet will be able to open and close. Next take two 3 by 2 pieces of anti-static bag and tape them over each of the holes where the outlet part would normally come out. Look at the pictures if you need help.
Step 3: Add Cash Pocket
Next take two 3 by 2 pieces of anti-static bag and tape them over each of the holes where the outlet part would normally come out. Look at the pictures if you need help. Now take a 7 1/4 by 2 3/4 piece of Anti-static bag and create a pocket on the inside of the wallet. Make sure that your cash will fit in it.
Step 4: Add the Memory Stick Holder
Take the memory stick holder that came with your memory stick and tape it to the inside of your wallet . You may need to grind down the bottom of the holder to make the wallet close.
