Introduction: Watering Can No Stress
This instructable arises from the need to have something that is halfway between a watering can traditional and a rubber for water, combining the advantages of one to the other without presenting large incidents.
It's a watering can that is continuously fed through a rubber
the water that fills continuously but that, if we stop to rest for a bit until you upload is full and no overflows.
Step 1: The Heart of the System
The heart of the whole construction is the tap propelled by a float that is used in the water tank discharge the W.C.
The second image shows how will their tubes, but, of course, still lacks something.
Step 2: Modifies It
To run the float to the inside of the watering can I had to reduce the length of the command bar of the valve. I then performed the holes to reconnect the two bar and to allow an eventual final adjustment of the system.
Using a self-locking screw I allowed a fine tuning of the location of the float.
Step 3: And Mounting
And now it is time to change the clipped to host the valve; as first I created a bore diameter appropriate to entry the tube which will subsequently the final fitting screwed male to which goes every time docked fitting female adduction of the feeding tube.
For a proper keeping of hole I put two seals including one in the internal and external to the one that is also visible in Figure successive.
Step 4:
The operation of the float is not easy because it involves the enter with your hand inside the watering can the tubing from hole. After some attempts the thing failed and I fixed the system through the fitting male end so that the bar and the float moved freely.
Step 5: The Conclusions
I know it is a semi serious idea but I liked the same built, and despite being a bit mad as what I think it may have its usefulness. What do you think?
Thanks for your attention and if you believe please vote for me! There I will be grateful
Goodbye to the next...
