Introduction: Wrist Dart Launcher
I am going to show how to make a cheap wrist dart shooter thats fun for anyone
Step 1: Supplies
You will need:
A type of adaptor shown below (can be obtained anywhere like Biglots Walmart or Kmart)
Broken or working headphones (Any work really its not like ur ganna listen to music on them)
A rubber band
A rubber band
Step 2: Step 1
1 The adapter you buy will most likely have at least one cord attached to it, rip off the cord so it is cordless,
2 Make sure u also cut off all wires sticking out because it could cause electracution
3 For the rest of the instructable have the adapter upside down so u could see the clip
Step 3: Step 2
Wrap the headphones under the clip around your arm until u cant wrap it anymore
Step 4: Step 3
Now to tighten it so it doesn't fall off your hand.
Weave the two era pieces under the wires wraped around your arms, under and over under and over
Keep wraping it until the ear pieces hang on their own so u dont even see a dangling wire
Step 5: Step 4
Now to finish,
Now that you have it tightly wrapped around your arm put in the rubber band under the lower part of the clip where the wires wraped around your wrist are.
Then part of the rubber band should be the outer part stretching behind the upper clip
Step 6: END
Now your done, take your projectiles, toothpicks, arrow picks, whatever and place the back on the rubberband then strech it so the tip it just littly touching the upper part and fire, you could also get a posicile stick and attach it to the clip so u could get the rubber band farther and shoot farther, other thanthat your finished, have fun and be safe, yours sincerely,
Water child
Water child
