Introduction: Jk Jeep Paracord Handles
About: I am a DIY guy. Before I knew about this site I had made many things, like 2 large cat trees, an R/C wagon, gas bike, and solar powered hot water heater. I'm sorry I haven't publish any of these but I have de…
So I wanted to buy grab handles for my JK but I have been really bored lately, and I'm super cheap. So I learned how to braid paracord. I played around with paracord for a little while so I am not sure if it is completely right but it works for me.
Step 1: Stuff to Buy
so I got enough paracord for 2 handles and I got 4 shackles.
Step 2: Stuff You Need
So you need to have scissors and a lighter and something like a pen or something like that.
scissors for cuting the paracord.
a lighter or match for burning the ends of the paracord so it keeps it from fraying. I used a torch to heat up the scissors to burn the ends and cut. it gives it a clean look.
Step 3: Measurements
measure the roll bar and how long you want the handle.
Step 4: Start the Braid
so I made a mental note that kept me in order.
1.white cord over the center.
2. white cord under black cord.
3. black cord under center.
4. black cord through white cord then tighten.
Step 5: Continue the Braid
5. white over the center.
6. white under black.
7. black under center.
8. black through white then tighten.
Step 6: Adding Color
I put a 3rd cord in the center of the braid since it's not for strength you can just add it when you want. once it's in the center fold it up then continue 2 braids. then fold it back down to the center. continue 2 braids. keep the pattern and you can add some color.
Step 7: Finishing
once you are close to the end wrap some leftover paracord but up into the center and continue to braid. once you are to the end you can use the pen and tuck the leftover paracord into the braid. and then you can trim the rest of the paracord with the scissors. done.
Step 8: Adding the Handle
now adding the handle is very easy. find where you want to add the handle in between the two wraps. instead of knotting around the shackle weave it in the side of the wrap's braid. then continue the braid and repeat. now you done with a solid jeep JK paracord handle.
