Introduction: Use Light Strip From a Printer Scanner
we have seen different colours coming of of the scanner
they are mainly.
red
green
blue
we can light it up just using some wire and 9volt battery
they are mainly.
red
green
blue
Step 1: Taking Out the Light Strip
now open up the and remove the motor and the gears
you are gonna need a fine screwdriver to open up the screw on the light strip
after
you are done taking it apart into pieces
don't. pull the. board on it
you will find 4 soldered area
be careful with them
use soldering iron to loss it
and then remove the board
after
Step 2: The Light Strip
now the light strip is apart
you can solder wires on the white stirp
Step 3:
the red dot is the positive
and the other three wire are of red green blue
Step 4: Finished
now its finished you can use a 9volt battery to light it up
and
if you have any creative way to use there strips please let me know
and
Step 5: Reusing It
if you broke the tri led on the end side
you can find this small led light
and stick it to the end side
it glows
its like a light saber as in star wars ????
