Introduction: K'nex Bin Bubbleponic/aroponic System.
About: I love K'nex, Plants, Electronics, Computers, Linux, Fish, Arduino, Minecraft, and my cat Serena (the cat in my profile picture)
In this instructable you will lean how to make a bubbleponic/aroponic system.I would like you to rate comment and give constructive criticism.
Supply's you will need.
1 Tote with fitting lid
4 ft. Fish air line tubing
1 Fish tank air pump
1 Sharpie
Net pots (amount will vary based on size of tote)
1 Airline T
2 small air stones
Tools
Dremal with sanding wheel or hole saw
Drill bits
Drill
Step 1: Trace and Cut
You will need to trace around pots.  Be sure to cut the hole slightly smaller then your trace line, this will insure a snug fit.
Step 2: Sight Glass (optional)
It is best to use a drill bit slightly smaller than your tubing, this will make sure that there is less risk for leakage. Make sure to  and drill a hole at the top and bottom, then pull the tube through.
Step 3: Aeration
Take the drill bit, tubing , t and air stones first drill a hole at the top. Pull your tube through put your t on the end of the tube inside the tub add a air stone on either side attach to air pump.
Step 4: Finishing Step
Place your plants in pots,throw the lid on and your done.
