Introduction: LittleBits Projects: Halloween Stick Figure Costume
Visit the littleBits project page for more DIY project ideas.
With just a few snaps you can use littleBits to make instant interactive wearables: make your own light-up stick figure costume, glowing dinosaur hoodie, and more!
This project uses the Limited Edition Stick Figure Costume Pack we introduced for Halloween.
This pack is enough to trace a stick figure for a tiny human, or a hoodie version for a bigger human. Each light wire is 4 feet long and capable of being folded, bent, taped and sewn onto a variety of materials. The pulse module allows you to blink your light wires at a frequency of your choosing.
The light wire has been a crowd fave for our bitizens, using it to invent customized light-up costumes for years. Now we have a super easy way for everyone to make their own costume guaranteed to light up any costume party or trick-or-treating!
To make a stick figure that lights up and stays on
- Make your circuit of Battery-->Power-->Light Wires
- You can sew the light wires onto a dark piece of clothing or use the hook & loop Shoes to easily attach to clothing.
To make a light-up costume that blinks:
- Make your circuit of Battery-->Power-->Pulse-->Light Wires
- By adding the Pulse the lights will blink. Similar to the above, you can sew the modules to dark clothing or attach with the Shoes
Bits You Will Need:
Other Materials Used:
- hoodie x 1
- needle + thread x 1
- sweatpants x 1
Step 1: Build the Circuit
Build this circuit: power + pulse + light wire + light wire.
Adjust the pulse to whatever speed you like. Use the hook & loop bitsnaps to secure your circuit so they don't separate. Use the adhesive hook & loop strip to adhere it to your material.
Step 2: Shape the Wire
Bend the lightwire into the shape of a stick figure. The lightwire is great because it holds the general shape once you bend it.
Step 3: Sew the Lightwire Into Place
Use a needle and thread to sew the lightwire into your clothing. We recommend light thread and dark fabric.
Step 4: Wear Your Costume!
Go forth and be spooky!
