Introduction: Note Pen
Have you wanted to talk to someone in your class without the teacher knowing?Being able to pass it right under her or his nose?Well here's an Instructable you can make in class!!!
Step 1: The Stuff
you need:
+4x4in. piece of paper
+a pen
+pliers
+someone to pass a note to
+a pen
+pliers
Step 2: Open the Pen
You need a pen (the cheap ones that are not retractable).You need to pull out the ink well first(!!!!!!don't pull out the tip that the ink comes out of!!!!!!).Then you pull the end cap off.
Step 3: Roll the Paper
You need to take your 4x4in. piece of paper and roll it around the ink well.Then yo slide the paper still on the ink well in to the back of the pen and pull just the ink well out.Let it sit in the pen for a day so it will be easier to roll it up after you take it out.
Step 4: Put It Back Together
Now put the ink well in the pen where you took it out at the being(put the long part through the hole in the paper).Then put the end cap on(not all the way so you can get the paper out) and your done.You use the ink well to get the paper out and you have something to right your note too.Explain how to use it in your first note.And make more than one 4x4in. piece of paper.
