Introduction: Peeled Potato Chips (crisps)
About: AussieAnglerGal is a crazy teenager who has a million ideas that she'll "get around to one day", runs around the bush like shes feral and does Distance Education from 400km away. shes got various siblings/clas…
Does it seem to you no matter how you cut a potato you can never get much from it? what if i told you only one or two potatoes can give you enough chips to serve 4-6 people ( as a side-dish)......
using a utensil you almost ALWAYS use in potato preparation!!!
sorry about the quality of the photos...my camera fell off a bench during another 'ible and i have to use my sisters camera
(thanks to my sister, CrazyBassFisherwoman, who helped with the photos!)
Step 1: You Will Need
Two large potatoes
vegetable or canola oil (for deep frying)
seasoning of your choice
you will also need
small saucepan
a colander
a vegetable peeler
a serving dish lined with napkins
Step 2: A Mountain of Chips...from One Potato!
in a sink a quarter full of water, peel your potatoes, removing the skin (using a knife, unless your careful, will take too much off)
i've heard if you scrub the skin before peeling you can also fry the skin peelings but I've never tried it myself
rinse potatoes to remove any dirt or loose skin peelings
over a clean surface, take your peeler and slowly peel thin strips off
wider, shorter strips will fry better then long thin ones
eventually the potato will get to small to peel anymore, just throw it away (or cut it up with a knife and fry it if your worried about wasting it)
Step 3: Very Important Step!
this step is very important and should not be skipped!
thoroughly rinse potatoes under running water, mix with a fork or clean hands until the water runs clear and the potatoes lose their "slimy" feeling.
this step removes the starch, with the starch left on the potatoes, they will not fry properly and the oil will go cloudy
drain any remaining water
Step 4: Deep Frying Time!
pour oil into a small saucepan,enough so that the peelings will be deep fried.
this does not require much oil.
heat the oil until nice and hot. to test if your oil is hot enough, drop a peeling into it and if it instantly bubbles around the edges, then the oil is ready.
carefully drop a few handfuls of potato into the oil, and gently stir with a slotted spoon or similar utensil, to separate peelings.
Fry until you can feel them going crisp (stirring a utensil through will test this..don't burn your fingers!) or they begin to go golden at the edges.
don't worry if they aren't completely crispy, they will be after a few minutes out of the oil
place them in a dish lined with napkins, etc and repeat with remaining potatoes
(sorry i didn't get any good photo's of them frying until golden-brown)
Step 5: Serve!
 Season and serve with just about anything you like! :D
these would make a good low-cost party food or appetizer
be warned though, they are like any potato chip..one just isn't enough!!!
thank you for reading my instructable
if you have any comments,questions,suggestions, please post a comment or PM me
AAG
