Picnic Table
Intro: Picnic Table
This instructable is for a large diy wooden picnic table which is easier to step in than a traditional picnic table.
It is made completely of two by fours (89x38)
STEP 1: Layout - Cutlist
second pic is metric ,third imperial.
If you are going to use a miter saw remember that most miter saw gauges are set up off 90 degrees to the back of the fence! (http://www.thisiscarpentry.com/2011/07/29/miter-angles-miter-saws/).
So for 51,2 degrees you have to set your saw to 38,8 .
STEP 2: The Two Benches
I used some m8 threaded rods to connect the leg constructions.
In total is have used 24 each 16 cm and have cut them when the table was ready.
Some coach bolt will even look better.
For the other connections i used wood screws of 80mm.
Click on the pictures for a larger version of the picture.
A google sketchup version can be downloaded here
STEP 3: The Table
For the legs of the table you need to cut out a piece for each leg.
STEP 4: Screw It All Together
The legs of the table must not be lower than the connection two by fours .
The horizontal connections are 50mm of the floor so it won't wobble on an uneven surface.
152 Comments
mickrwall 1 year ago
The order of assembly would help.
Tks
Mike Wall
celedore 1 year ago
.07 = 1/16
.11 = 1/8
.17 = 3/16
.59 = 9/16
.67 = 11/16
.69 = 11/16
.82 = 13/16
.90 = 7/8
.93 = 15/16
.98 = 1
cmichguy765 3 years ago
LianeT 1 year ago
LianeT 1 year ago
marinagardner3 2 years ago
chrisarcus74 4 years ago
thomasluppi 2 years ago
christybowling 4 years ago
PeterG149 3 years ago
griz 3 years ago
tdove 3 years ago
Candy Tyacke 3 years ago
pciarrochi 3 years ago
Magderie 4 years ago
BrendaR112 3 years ago
Mac Adoug 3 years ago
