Introduction: Pocket Mini Air Conditioner 9v Battery
About: cheap and easy tricks
a small air conditioner that can be made under Rs100 or $5-10 maybe less
works with simple science can be used while doing anything
but can be used by one person at a time...
Step 1: You Will Need...............
you will need:
a foam burger box
a fan(can be made yourself by a motor and blades)
switch
9v battery
wires
ice
little water
tools:
cutter
screwdriver
glue
Step 2: X Marks the Spot
mark what you need to cut like the cold air window and space for the motor
Step 3: Cut It
cut the marked holes
Step 4: Fan It
put the fan in the hole and give it support as shown in the pic
Step 5: Power Is the Key
now add the switch and battery in series now add ice and water in the box close it and turn the fan on ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh........................................cold air breezez
BEAT THE HEAT!!!!!!!!!!!
