Introduction: Snapped Exhaust Repair
snapped exhaust repair with hose clips and exhaust putty
Step 1: Prepare Tools
I got my inspiration from this instrucable:
https://m.instructables.com/id/How-to-fix-your-car-exhaust-without-welding-or-po/
You will need to prepare your tools, ppe and working environment.
PPE
gloves, glasses and dirty clothes
TOOLS
screwdriver
tin snips
(optional) screwgun
scissor jack
inspection lamp
MATERIALS
tin can
exhaust repair putty
hose clips
paving blocks
PPE
TOOLS
screwdriver
tin snips
(optional) screwgun
scissor jack
inspection lamp
MATERIALS
tin can
hose clips
paving blocks
Step 2: Raising the Vehicle
Check your planned area of work is flat and level, block off the front wheels to stop the car moving when lifting, make sure the handbreak is fully engaged.
Using the weight appropriate jack lift one side slowly and carefully build the the blocks to the axl, drop the jack slowly.
beware the vehicle could tip and YOU SHOULD NOT WORK UNDER THE VEHICLE ON THE JACK ALOWN and repeat on the opposite side.
be careful as the vehicle weight shifted and dropped whilst lifting.
Step 3: Locate the Snapped Exhaust
locate the break and plan your approach as the snapped exhaust has left me with a slight lip on the silencer.
I decided to apply it externally, it can be done internally too please check the previous link to see how.
Step 4: Prepare the Tin Can and Paste
I cut off both sides of the tin and removed the label, using the tin snips I flanges both ends.
I opened the flange on one side.
I cleaned the exhaust of rust and dirt and prepared the putty.
Step 5: Dry Fit and Check
I found it quite hard to fit the tin on to the exhaust, I cut the tin down one side, wrapped it and attached the clips it fitted snuggly, happy with its shape I removed it to apply the putty.
Step 6: Putty and Tin Can Assembly
I re-read the putty instructions.
realigned the snapped area, started to apply the putty and work it in to the cracks, I found it easiest with fingers and thumb.
I applied the putty into the tin, trying to cover all parts.
wrapping the tin around the joint and postioned the hose clips, I used a screwgun to speed up the process and finished the a screwdriver.
sorry there isn't any pictures as I held the pressure on the tin.
once I was happy with the clips I reapplied the putty acrossed the flanges and the side of the tin can.
Step 7: Test Your Work
I checked the flow from the exhaust, and it seemed to be working fine, I ran my hand around the joint and couldn't feel any gases escaping, I took the opportunity to check the rest of the exhaust.
I left it running for a while whilst I tidied up as the the heat should help the putty set.
Step 8: Repeat Step 2 in Reverse
reverse step 2 being careful whilst using the jacks.
Step 9: Cleaning Up
the putty should set overnight
Remember to wash and take care of your skin. oil and chemicals can cause severe reactions.
hopefully this guide has helped you,
thank you for reading my first instrucable.
constructive criticism is welcome
