Super Mario Lamp
Intro: Super Mario Lamp
Here is my first IKEA hack!
Notice that you are working with hazardous voltage in this instructable!!!
Only do this if you know what you are doing!!!
STEP 1: The Component List
You need something like this parts:
- 1x sangen (IKEA lamp)
http://www.ikea.com/de/de/catalog/products/1019662...
- 1x cover distributor
http://www.ebay.de/itm/Deckenverteiler-Eisen-80x25...
- 1x pressure switch
http://www.conrad.de/ce/de/product/700529/Drucksch...
- 2x Flat-plug-sleeve
http://www.conrad.de/ce/de/product/792808/Flachste...
- 1x Butt connector 1.5 mm ²
http://www.conrad.de/ce/de/product/737048/Stossver...
- 1x color yellow
http://www.amazon.de/Dupli-Color-722493-Aerosol-10...
- 1x color black
http://www.amazon.de/NIGRIN-74112-Lackspray-schwar...
- 1x 230V led bulb
http://www.amazon.de/s/ref=nb_sb_noss_1?__mk_de_DE...
- 3x Lighting terminals
http://www.amazon.de/Wago-50-St%C3%BCck-Verbindung...
- 1x Universal Power Supply
http://www.amazon.de/Ansmann-5111233-Universal-Ste...
- 1x ton, record module (thanks to Mcobit)
http://www.conrad.de/ce/de/product/191044/10-SEK-T...
- 1x Pack sugru or glue
http://www.amazon.de/Sugru-Selbsth%C3%A4rtender-Si...
a piece of plastic for maximize the button size
a little bit glue
Wire:
ca.50cm 1x1,5mm2
everything together should not cost more than 100€
STEP 2: The Case
Build everything off what at the IKEA lamp is soluble.
- Take the yellow color and dyeing the box completely. Also the plate of the bottom.
- Do it where you do not mess up everything yellow.
- Let it dry.
- Take the template (images) print them out and cut them out.
- Take the black paint and spray a question mark on.
- Make sure that the question mark is not the wrong way. (because I did it at the first time)
- Let it dry.
- cut a hole for the button in the plate of the bottom (image 2)
- click the button in it
STEP 3: The Circuit
look at the image.
ceiling:
- cut off the plug of the lamp
- press a hole in the middle of the cover distributor
- put the wire through it
make a knot for strain relief
lamp:
- solve the strain relief by the socket
- open the socket
solve one wire
connect this with the connector and a piece of the single wire
(this goes to the button)- another wire go from the free clamp to button
- press the two Flat-plug-sleeve at the ends of the wire
- cut a pice of the socket (for wires)
- click it all back together
maximize the button size with piece of plastic and glue
Make sure the strain relief and the isolation!
STEP 4: Optional With Sound
see images.
STEP 5: The Installation
look at the image.
Make sure again the strain relief and the isolation!
Think about it you are working with hazardous voltage!!!
Remove or disable fuses.
secure against re. and measure bevor work.
cable it like your lamps before, it easy.
If you want to go the save way connect the yellow/green one to the metalgrid.
7 Comments
StoryAddict 11 years ago
You should add the sound effect too!
Anred Zynch 11 years ago
I thought about it. But it gets complicated, I need small lightweight components, a space to accommodate them and would bring everything to the correct voltage-level.
Ok, it is done!
ewilde1 11 years ago
krispunke 11 years ago
Muhaiminah Faiz 11 years ago
Awesome!
mincraftlover 11 years ago
