Introduction: The Centrifugal Puzzle
Do you want to wow your friends,
Do you like working with wood,
Do you enjoy brain teasers,
if so read on...
Everyone likes a good brain teaser every once in a wile. A puzzle that can frustrate the most powerful minds, yet has simple solution. The centrifugal puzzle can do that!
Step 1: Things You Will Need
You will need 2, 2cm x 3.5cm blocks of wood around 30cm long,
2 small dowels,
2 drill bits, one for the screw and one slightly larger than the dowel rod,
A drill,
A scroll saw,
A scroll saw blade.
2 small dowels,
A drill,
A scroll saw,
A scroll saw blade.
Step 2: Measuring
Using a pencil and ruler find the half way mark .Measure 1cm out from the line on each side. Make 2, 2cm lines up from the line you just drew. Now join the two lines so you have a 2cm x 2cm square. Do the same on the other.
Step 3: Cutting
Using the scroll saw cut your marks. Your two pieces of wood should fit flush with each other .Cut one piece in half (see picture) this part does net need to be exact.
Step 4: Drilling
Drill 2 holes slightly longer than you dowels in the wood. put the dowels in then glue your pieces back together. drill a hole about 3mm larger than you dowel in the other piece of wood (see picture 2).
Step 5: Paint It
Use semi gloss spray paint and spray around 8 inches away from project.
Step 6: You Are Finished
now put the two pieces together and shake it a couple of times. Now try to take the two pieces apart. You cant I know, I will give you a hint its in its name. still cant figure it out scroll down.
Take the puzzle and give it a good spin on a flat surface now pop the piece off and go fool your friends.
