Introduction: Wooden Fortuneteller Charms
I got the idea of star dust the movie and this is a miniature version and I'll make the full-size version soon.
you will need:
1)pen knife (or sharp knife)
2)a file (not a nail file)
3)an assortment of permanent pens of your choice ( I use black but you can do differently and I recommend sharpys )
4)3 peace's of 8cm long, 5mm wide and 3mm thick wood
you will need:
Step 1: Cuting
1)first we cut the wood at 3cm3mm
Step 2: More Cuting
2)next to save time measuring it again al-line the peace you just cut next to the other peace of wood and cut at its end to create an exact copy of it repeat for all the peace's of wood(the sixth peace is a spare so still work on it cos if you mess up you could need another and or if you loose one)
Step 3: Filing
3)next get the file and file the edges to make them smooth but leave out the top and the bottom sides because you'll need them later
Step 4: Engraving
4)next get the sharp knife and engrave one side of each of the peace's of wood with symbols of your choice (I prefer zig-zag paterns in the middle and random lines at ether end ) but only one side leave the other side blank or you'll ruin it(make sure that the engravings are quite deep and not too wide because it will be important later)
Step 5: Colouring
5)now you are ready to colour them in with colours of your choice ( if your doing a dark colour thend dont colour the inside of the engravings cos you wont see them but if your using lighter colours then colour in the engravings with a dark colour black works best)
Step 6: How to Play
6) how to play= hold the 5 peace's in your hand,then ask a question that can only be answered by "yes" or "no"(or you could get some one else to ask you a question) and then shake them then drop them on a table(or sutable surface of some sort ie grass, mud or water are not sutable) next check you answer by using the key below (memorize it so your like a fortune teller)
2 symbol side up + 3 blank side up = no
1 symbol side up + 4 blank side up = no
3 symbol side up + 2 blank side up = yes
4 symbol side up + 1 blank side up = yes
(its useful if you cant decide what to do eg ask the question "shall I go to the cinema instead of going to the restaurant" if your stuck between the two it can help you decide quicker)
