Introduction: Null
This design is actually a collection of designs, centered around games since the Bose Build speaker is mostly for kids/teens. I designed a set of panels that can be swapped and allow the user to play games : - the first STL file is a maze designed for FDM printing : the player has a piece that is also included in the file and must also be printed. There are four starting points for the maze, one on each side, and the goal is to get to the middle of the square. The piece is designed so that the player can insert it from the start and then slide it inside the maze without it falling. - the second STL file is another maze but it's designed to be 3D printed on a SLA/SLS printer : the piece for the player to play is already inside the maze and can not be taken out but can only slide inside the maze - the third and fourth STL files go together on opposites sides of the speaker : they are two tic tac toe boards, one holding the 9 Xs and the other one holding the 9 Os : the players take them all out before playing and can use them on any of the 2 sides - the fifth STL file is meant to replace the top panel of the speaker, as it includes a helicopter-like top and a string with gears that the user can pull in order for the helicopter to fly (I haven't tried it to be honest). - finally, the last file is a Fusion360 project that includes an add-on that I wrote based on some code I found on rosettacode.com that allows the user to generate new mazes (that can be used for the 1st and 2nd design). Thank you for your time :-)
BOSEBuild Design Challenge
