Introduction: How to Make Cabinets
About: Build instead of buy....most of the time.
Before I get started with the build process I want to let you know that at the end of this instructable is a free downloadable PDF guide going into greater detail than I will in this instructable. The goal of that PDF is to give you general direction with a strong building method for cabinets. Hopefully it will be of some use to those who are looking to build cabinets and are looking for a reliable method.
The cabinets I am building in this instructable are bathroom vanities. The same construction methods can be used for kitchen cabinets as the only difference between them and kitchen cabinets are the height and depth. The design I am using is a very conservative straight line design. Nothing fancy. No edge details. The drawer fronts are just a piece of 1x6 and the doors are simple tongue and groove construction with floating plywood panels. I also have a guide to making tongue and groove cabinet doors on the table saw that I will cover in another instructable.
Material lists for cabinets can vary from cabinet to cabinet depending on size and style but for a generic list you will need the following:
  • Plywood for the side panels, bottoms, and any other structural piece that won't be seen.
  • Plywood or a solid wood panel for the door panels.
  • Solid wood of choice for the face frame, door frame, and drawer front.
  • Drawer slides for however many drawers you are making. I used Euro style drawer slides in this build.
  • Cabinet door hinges for whatever style door you are making. I used overlay door hinges.
  • 1-1/4" pocket hole screws.
You will need the following tools:
  • A table saw or circular saw for all of the cuts.
  • A drill.
  • A pocket hole jig. Any kind will work.
Using power tools incorrectly can be dangerous. If you are at all uncomfortable doing something don't do it.
Step 1: Prepare the Case Panels
To start I cut my full sheets of plywood into more manageable sizes with a circular saw. It's much safer and easier to take half size sheets of plywood to the table saw than a full size sheet when possible. I used cheap 3/4” pine plywood for this. (pic 1)
At the table saw things are much easier. The main pieces to cut here are the side panels, the bottom shelves, and then rip the remaining strips that will later be cut to length. (pic 2)
Each side piece receives a 3” x 3” notch in the bottom front corner. This is for a toe kick. (pic 3)
Two vanities so four sides total get this notch. A good blade in a jigsaw makes a huge difference in cut quality. These cuts felt the same as if they were made with my table saw. (pic 4)
Step 2: Face Frame Pieces
A cabinet face frame is the front frame of a cabinet that will establish the location of all of the doors and drawers as well as give some structural stiffness to the rest of the case. The overall size of the face frame is determined by how many doors and drawers you want to have. Specific dimensions are covered in the PDF plan.
All of the face frame pieces were ripped from 1 x 6 pine boards. I often get asked what do I do to prevent my boards from warping because I use cheap pine. Well, the biggest thing I can say is to spend a lot of time picking out quality boards. If the place you get your lumber from doesn't allow you to do that then they don't want your money. That's OK because their competitors will. I generally get mine from Lowes as it's the only kiln dried supplier I have near me. Your mileage may vary. (pic 1)
The general construction method for these cabinets is pocket holes. There are a lot of different pocket hole jigs and machines out there that will all complete the same task. If you are doing a lot of projects using pocket holes a pocket hole machine may be a justifiable option for you. At the same time if you aren't going to be doing a lot of pocket hole projects a simple $20 pocket hole jig will be just fine. (pic 2)
With all of the pocket holes cut the face frame assembly goes very quick. (pic 3)
Step 3: Begin Assembly
After the face frames are complete I attached the side panels to the face frames with pocket holes as well. Each of these cabinets that I built had one side that was going to be against the wall so on those sides I put the pocket holes facing out. On the sides that were going to be exposed I put the pocket holes on the inside of the cabinet but I made sure not to put any where you could easily see them if the door was open. (pic 1)
The bottom shelves are secured with pocket holes as well. The pocket holes are on the bottom so you will never see them. (pic 2)
To give a little more support to the top perimeter of the cabinet as well as provide a surface to screw through to secure the countertop a couple strips of plywood are attached to the top inside of the side panels. (pic 3)
To add a little more access to everything stored in the bottom of the cabinet I added two slide out trays in the larger vanity. These are very easy to make and I've already made a very quick tutorial on them on my website. Disregard this tray option if you want. (pic 4)
Step 4: Door Prep and Building the Drawers
I knew the doors would be coming up soon so I prestained the 1/4” plywood panel that will be cut for all of the doors. (pic 1)
While the stain dried I knocked out the drawers real quick. The drawer bodies were just 3/4” plywood pocket hole screwed together with 3/8” plywood glued and nailed directly to the bottom. Quick and easy. Exact dimensions to follow are given in the PDF plan. (pic 2)
For mounting the drawer slides see the instructions that came with your specific style drawer slide you chose. With the drawer slides mounted on the bottom of the drawers and in the cabinet I made sure everything fit. (pic 3)
As I said earlier, the drawer fronts were nothing more than a 1 x 6 cut to length. I cut all of the drawer fronts out of a continuous board so the grain would flow from one drawer to the next. To secure them I screwed through the inside of the drawer and into the drawer front. (pic 4)
Step 5: Building the Cabinet Doors
I'll do a separate instructable on tongue and groove doors in the future so I won't get too complicated here. A grove is cut with a regular table saw blade on all of the door rails and styles to fit the plywood panels. (pic 1)
I used my dado blade to cut the tongues on the ends of my rails. This was a lot easier to dial in than I had thought it would be. Just use a test block to sneak up on your fit. (pic 2)
After two rails are glued to one style the plywood panel can slide into place. Then the other style can be glued on. I only used glue on the tongues of the door frame and left the interior panel floating but if you are using plywood you can use glue on the plywood panels as well if you want. Don't use glue on the panel if you are using a solid wood panel. The expansion and contraction of a solid wood panel will cause problems with the door assembly if glue is used. (pic 3)
Step 6: Finishing Steps
To increase visibility I painted the interior of the cabinets white. It will help brighten up the dark areas when you're trying to find something. (pic 1)
After everything was sanded and stained I sprayed a clear water based finish. I have been using an inexpensive Harbor Freight HVLP spray gun for a few years and love it. It greatly speeds up the process of applying finish and it's easy enough that anyone can do it. There are several tutorials on YouTube about spraying finish with a HVLP gun. (pic 2)
And the last step is to install the door hinges. I didn't put any door or drawer pulls on these as the person who was going to get these wanted to install them herself. (pic 3)
Step 7: Enjoy the Cabinets YOU Built
Hopefully you are able to use my video and this instructable as a general flow of how to make your own cabinets. If you would like more detailed instructions with dimensions click here to open my free PDF guide or right click and select "save as" to download it to your computer.
If you enjoyed this instructable I invite you to check out my website jayscustomcreations.com where I have been posting new weekly content for the past two and a half years. Good luck with your next build!
