Introduction: Rainbow Leaf Board
In this instructable, I will show you how to make a home décor circular board using acrylic paint and a Medium density fiberboard board (MDF). The theme of this project is based on the Rainbow colors. The leaf is painted with acrylic colors. The colors of the rainbow are: Red, orange, yellow, green, blue, indigo and violet. This decorated board is very compact, light in weight and looks cool. Let’s get started!
· A Circular Medium density fiberboard (MDF board ; diameter = 30 cm)
· Acrylic Paint box
· Paint brushes
· A plant leaf
· A color plate
· Tissue paper
· Water
Step 1: Preparation of Circular MDF Board
- Clean the MDF board with soft cloth to remove stains or dirty marks.
- Take white acrylic color and a paint brush. Paint one side of the MDF board with this color and leave it for dry for few minutes.
Step 2: Painting Leaf
- Now, take a plant leaf (you can use any plant leaf as of your choice). Apply paint on the other side of the leaf where the volumetric veins are present.
- After applying color on the leaf, put the leaf on whitely painted surface of the MDF board and lightly press it with a tissue paper to get good and visible impressions of leaf veins.
- After printing one color wash the leaf as well as paint brush properly with water and then apply other color.
- I am using rainbow colors one by one to paint plant leaf and printing its impression on MDF board.
- I have very limited colors so, I prepared Violet color by mixing following colors:-
Blue Color + Red Color + White Color = Violet color
Step 3: Paint It
- Apply different rainbow colors one by one to paint plant leaf and make at least three impressions of each color.
- You can put the painted leaf in random way or in a regular pattern on the board.
- I am putting the leaf in random way on board to get random and colorful expressions.
- Be careful while putting leaf on the board and removing it otherwise leaf may damage.
- After applying each color leave the board for dry for few minutes.
Step 4: Final Presentation
- When the colors are dried if you see certain stains or marks on the board then you can use white acrylic color to hide these stains or marks to give a final finish and leave it for dry for few minutes.
- Now, your own DIY colorful home décor item is ready to present.
- You can paste this board on your room wall or in your showcase with the help of double sided tape.
- Hope you like this project. Thanks for watching.
Colors of the Rainbow Contest
