Introduction: Bottle Light - Upcycle Vape Battery
See a lot of these vapes getting thrown out.
Turns out the internal battery is rechargeable.
Runtime 6-8hrs per charge
Use UBSC cable to charge
Cost of project is less than $1
They are great for camping, mood lighting, bedside lamp even blackouts
1x used vape battery - to suit the size of the bottle neck
1x push button switch
1x TP4056 charging module with USBC port
1 x 15ohm resistor
1x USBC cable for charging
50cm led light wiring
Step 1: Soldering the Battery
Start off with soldering negative tab of battery to B- connection on the the charger board
Step 2: Adding the Switch and Resistor
Solder the resitor to the OUT- connection on the charger board.
Solder the switch to the resistor - make sure there is enough length to have the switch orientated close to the USB charge port
*Note - will need to experiment with correct connection to the switch for proper on/off operation
Step 3: Adding the LEDs
Need to check which way the LEDs connect. the wire has a fine insulator that needs to cleaned off before soldering to the battery and charger board.
The positive side of the LEDs will need to be connected the charger board B+ connection and then to the positive side of the vape battery
Step 4: Final Assembly
At this stage you can test if the circuit works. If not it could be the battery too flat. Plug in charger cable and charge.
The circuit should work - If not the LEDs are connected the wrong way
If everything is working then use hotglue to secure they switch to the charger board.
I use black electical tape to cover the board.
You will need to see how big the neck of the bottle is when choosing the size of the battery
Anything Goes Contest
