Introduction: Emoji Charm Bracelet
Jack and I made this easy charm bracelet with our favorite emojis and icons. All of the supplies can be found in a big box craft store. The activity takes around an hour for an adult and child.
Gather supplies:
Clear Shrink Film by Grafix Arts $6.50 for a pack of 6 ... can substitute with #6 Plastic food container.
Sand paper between 300 - 500 grit.
two pliers
jump rings $2.99 a pack at craft store
7.5" chain bracelet with clasp $3.99 at craft store
black Sharpie marker
colored pencils
blank paper
ruler
scissors
single hole punch
toaster oven or conventional oven
Visit this link for complete Shrink Film Instructions by Grafix Arts.
Step 1: Draw Designs
Using a pencil, we drew a grid 2 inches wide x 6 inches tall (roughly twice the size of our desired charm). Inside the grid, Jack and I drew our favorite icons and emoji's. Then I placed the clear shrink film on top and traced simple outlines with a black sharpie marker and Jack colored the designs with colored pencils.
Step 2: Cut Out the Charms and Punch Holes
Cut out charms with a small margin around the edges. It's ok to leave out some contours, such as between bunny ears. Punch a single hole now, before baking. This is where each charm will hang.
Step 3: Bake
Preheat conventional or toaster oven to between 300 and 350 degrees Fahrenheit. Bake charms on a cookie sheet lined with paper or parchment for 2-3 minutes. While inside the oven, charms will curl up then flatten to around half their original size. Remove from the oven and wait a few moments for the charms to cool before touching.
Step 4: Attach Charms to Bracelet
Use two pliers to twist open a jump ring and attach a charm to a bracelet link. Use one pliers to grip one side of the jump ring and the other to twist the jump ring open. Slip the charm onto the jump ring and hook it onto a bracelet link. Twist the jump ring closed again with the pliers. For link spacing, count bracelet links and divide that number by the number of charms you have. Our bracelet has 24 links and 8 charms, which gives us optimal spacing of every 3 links.
Plastics Contest
