Introduction: Fixing a Stuck Switch on a Vintage Circular Saw
The switch on my powerful 1970s 71/4 inch Super Sawcat on the left was sticking and then froze in the on position! Not exactly a safe way to operation a powerful cutting tool. No replacements are available anymore so I found a similar saw, a Builders Sawcat to use for parts ( on the right) but its in too good a shape to cannibalize. Plan B was to take the switch apart and attempt to repair it. I found a quick non destructive fix that worked instead.
Screwdrivers to disassemble the saw handle with ( like many old tools it had been repaired previously and required Flathead, Robertson & Phillips screwdrivers) . Electric heat gun. Safety gloves
Step 1: Assessing the Problem
When I tried my original saw there is no click & it just runs and won't shut off unless I pull the plug.
When I tried the Saw I got for parts the switch makes a very healthy click. and works turning the saw on when pressure put on the switch and cutting the power when pressure is released. Having a comparison to know how it is supposed to sound helps. Even when it worked I don't remember it clicking like that.
Step 2: Assessing the Problem Part 2
When I first disassembled the handle the switch was easy to access and there even was a circuit diagram! I looked online for replacement parts but nothing of that vintage is available anymore and this particular switch has 6 attachment points for wires and any possible modern replacements I might try only have 2 or 4 wires. A second saw I found for parts turned out to be too good to use for that purpose.
Step 3: Attempting Plan C- Non Destructive Repair
Original plan was to drill out the rivets and take the switch apart, lubricate it and hopefully get it back together in working order. Before I started drilling into it I thought about what non destructive options might work. The switch has a brown bakelite like body and opaque plastic on the bottom but no holes or places i could try spraying in contact cleaner. Then I thought to try heating it with an electric heat gun on low setting. That worked!
Step 4: Getting the Switch Working Again
I heated the switch on low heat, rotating the switch and heat gun so I didn't melt anything. After a few minutes I started working the switch.
For safety I recommend wearing work gloves to protect your hands from the heat. Heatguns can cause burns.
It took a few minutes but eventually the switch started clicking consistently & it has stayed functional even after it cooled down.
Step 5: Conclusion
Sometimes simple solutions actually work. I plan on trying the same technique on a other old tools I have with with sticky or slow working switches.
